Post-Installation Documentation
I am looking for a 'slick' report or method to document a Unity installation. We recommend customers to create a change control book for documenting the server configuration. Can anyone recommend a method of putting together this type of server configuration information ?
Thanks in advance
jrezab
Bronze
Re: Post-Installation Documentation
If you're looking for a way to record the settings on each page in the Unity SA, you can print out these worksheets:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity31/wsheets/index.htm
I am looking for more of a solution like "ART" that is available for call manager.
I also tried to create some crystal reports using the tools included in Unity but cant get the documentation that I want.
Right now I am using the DUMP tools and creating a report manually.
JR
Bronze
JR,
I'm not familiar with CallManager's "ART", but I do know that we don't provide any docs for creating custom reports using crystal reports. So your manual process is the only way to go for now.
Nancy
135
