Community Member
Power over ethernet model 7912 and 7970
Another question,
I use power over ethernet, is only sufficient insert plug rj45 in the lan port of phone?
Sorry for my bad english
Thank's
Hall of Fame Super Silver
Re: Power over ethernet model 7912 and 7970
Yes, all you need to do is plug in the ethernet cable to the phone and the phone will get power from PoE switch.
Chris
Community Member
You may want to confirm your power requirements. The 7912 and 7970's are rated differently.
Depending on the type of switch, you may be able to get away with just plugging it in, but with the 7970, you may still need a powerbrick to make sure you get full power to it. If it is a 7971, those need even more juice. Check out:
http://www.cisco.com/en/US/products/hw/phones/ps379/products_administration_guide_chapter09186a00803b144f.html#wp1067445
Here is some infor from the doc:
Cisco IP Phone 7970G in low-power mode
6.3 W
Approximately 1/2 screen brightness
Cisco IP Phone 7970G in full-power mode
10.25 W
Full screen brightness
Cisco IP Phone 7971G-GE in low-power mode
15.4 W
Near full screen brightness
Requires Cisco-approved external power supply
206
