07-25-2001 06:51 AM - edited 03-12-2019 12:02 PM
I am looking for a predictive dialer to integrate with Cisco CallManager. I would prefer one with TAPI or JTAPI integration as opposed to tie lines but any proven solution would be entertained.
07-30-2001 10:05 AM
Check out Interactive intelligence www.inin.com
07-31-2001 07:12 PM
I did speak to them and am trying to get them to quote one without success. However, the contact at i3 mentioned that they do not work over IP since CallManager does not report back call progress tones over IP. In MANY conversations with Cisco they recommend these vendors us JTAPI to create this as an application using Cisco trunks and I have yet to find a solution like this.
07-31-2001 05:57 AM
Another company who can offer this functionality are ARC Solutions, http://www.arcsolutions.com. It's not full "predictive" dialling but "power" dialling, worth some investigation though as their integration with CCM is very tight. We have partnered with them and found them to be very helpful.
07-31-2001 07:24 PM
I sent them a message and am waiting a reply. I have heard that these solutions are not working over IP since CallManager does not report back call progress over IP and we need to revert to tie lines. This is okay but nobody at Cisco can even confirm a tested solution or one in production at all.
08-01-2001 05:48 AM
What do Cisco suggest?
08-16-2001 09:11 PM
The ININ solution integrates using JTAPI whioch is due in about a month. The option available are in using ICS-7750 blade or by using a seperate server.
