Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Prefixing Digits for SRST mode...
Hi all,
We have a callmanager system where users dial 7 digits internally (as oppose to the usual 4 digits). The PRI sends in 4 digit DID and we prefix them with 3 more digits in the callmanager gateway configuration page to make it 7 digits.
In SRST mode, I am trying to setup the PRI to do the same thing. I am using the translation-profile incoming prefix544 to try to accomplish this. However, when testing in SRST mode, it doesn't prefix it at all. Please see configuration below.
I verified the translation rule by using the test voice translation-pattern and that works fine. For example, when entering 1100, the test voice translation properly returns "5441100". When I go into SRST mode, I see the call come in the PRI (debug isdn q931) but it doesn't prefix the "544" so it can't match any of the SRST configured phone.
Any ideas or help would be appreciated. Is there anything obvious that I missed in the configuration below?
IOS version is 12.4(9)T enterprise voice running on a 3845.
Thanks in advance!
Van
----------snippet of configuration------------
voice translation-rule 1
rule 1 // /544/
voice translation-profile prefix544
translate called 1
application
global
service alternate default
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
controller T1 0/0/1
framing esf
linecode b8zs
controller T1 0/1/0
framing esf
linecode b8zs
controller T1 0/1/1
framing esf
linecode b8zs
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-dms100
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:23
no ip address
encapsulation hdlc
isdn switch-type primary-4ess
isdn nsf-service sdn
no cdp enable
router eigrp 2
passive-interface default
no passive-interface GigabitEthernet0/0
no passive-interface GigabitEthernet0/1
network 10.106.0.0 0.0.255.255
no auto-summary
no ip http server
no ip http secure-server
ip tacacs source-interface Loopback0
voice-port 0/0/0:23
voice-port 0/0/1:23
ccm-manager fallback-mgcp
ccm-manager redundant-host 153.7.43.64
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 153.7.43.64
ccm-manager config
mgcp
mgcp call-agent 10.105.0.4 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
mgcp package-capability srtp-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
dial-peer voice 1001 pots
preference 1
destination-pattern 9T
progress_ind alert enable 8
incoming called-number .
direct-inward-dial
port 0/0/0:23
dial-peer voice 1002 pots
preference 2
direct-inward-dial
port 0/0/1:23
call-manager-fallback
max-conferences 24 gain -6
transfer-system full-consult
limit-dn 7910 1
limit-dn 7935 1
limit-dn 7940 1
limit-dn 7960 3
limit-dn 7970 1
timeouts interdigit 6
ip source-address 10.106.32.28 port 2000
max-ephones 720
max-dn 960
voicemail 917149266827
Re: Prefixing Digits for SRST mode...
Van,
I haven't personally done this but this might be like COR where you need to specify it outgoing to the ephone. Try using the below command.
translation-profile outgoing prefix544
Please rate any helpful posts
Fred
I'm not sure, but I think prefix544 is just a name, first you must create a voice translation-profile and all necessary translation rules.
look at
http://www.cisco.com/univercd/cc/td/doc/product/voice/its/cme33/cme33sa/cme33phn.htm#wp2317590
Van:
Did you ever get this to work? I need to do the same exact thing. Have to prefix 47 in front of the 4-digit DID number.
Rob
Hi Rob,
Unfortunately, I never got a chance to test the solution offered. Once the network was in place, and since I'm a subcontractor or a contractor, I could not take the network down.
I opened a TAC case and TAC suggested I added the translation-profile to the voice-ports. As per TAC, the profile will only be in affect for H323 calls and not mgcp.
Try this and let me know.
voice-port 0/0/0
translation-profile prefix544 incoming
I would like to know how this is done as well..please let us know if you can.
Bronze
If I'm not mistaken you need h323 dial-peers when operating in SRST mode. That's where you can apply translation profiles.
Also, you might need service default command under ccm-manager fallback-mgcp.
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_configuration_guide_chapter09186a00806674c3.html#wp1351962
this is what i've got.
translation rule test gives me a 47 in front of the 4-digit number which is what i need.
waiting for a chance to test it:
translation-rule 1
Rule 1 ^7 477
translate called 1
Rob
Hey Vincent,
I started it out by placed the "translate called 1" under the call-manager-fallback and it never worked. TAC suggested I put the commands in the voice-port.
Van
van
if this doesn't work, i'll put it under the voice port and give it a shot
thanks
rob
rob,
in SRST mode, you have to put the translate statement under the pots dial-peer
EXAMPLE:
rule 1 /\(^1...$\)/ /1212222\1/
rule 2 /\(^3...$\)/ /1331322\1/
voice translation-profile APPEND
translate called 1
dial-peer voice 1 pots
direct-inward-dial
dial-peer voice 100 pots
destiantion-pattern [12]...
translation-profile outgoing APPEND
port 0/0:23
** this allows DIDs in the 1xxx and 3xxx to have the E164 info appended to their outbound dialing string.
(I have this working at a customer site, BTW....)
Hi Vincent,
The configuration with the translation profile applied at the voice-port does work. I finally had a chance to test it at the customer.
Van
van
so the translation profile needs to be under the voice-port, not under the fallback, in order to work?
thanks
Rob
yes.
You can try this under the call-manager-fallback instead:
dialplan-pattern 1 .... extension-length 7 extension-pattern 544....
Where the first set of dots is for the 4 digits being sent from the Telco, and the extension pattern adding the 544 onto the beginning of the 4 captured wildcard digits.
I have never done exactly what you are asking for but this may work.
Please rate helpful posts!
Best,
JG
218
