Community Member
Prerequisites for cRTP
Hi!
Anyone knows wich are the prerequisites for cRTP take place? Wich are the required fields and values in the RTP message?
Thanks!
1 REPLY
Bronze
Re: Prerequisites for cRTP
cRTP is processor intensive and is recommended for low-speed serial links or if you want to save the bandwidth. Coming to prerequisites, CRTP is supported on serial lines using Frame Relay, High-Level Data Link Control (HDLC), or PPP encapsulation. It is also supported over ISDN interfaces. Please refer the following links for more information...
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800ca61b.html
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/qos_c/qcprt6/qcdcrtp.htm
110
