Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Presence not coming...Plz help
The error is Presence:Failed to connect,invalid credentials
The screenshot is attached herewith
Please suggest some troubleshooting steps
Re: Presence not coming...Plz help
Make sure you have everything configured correctly.
What do your troubleshooter say on the server, any issues there such as the SIP Publish, CTIgw, etc?
What version CUPS are you on?
On CUCM, did you associated the Line Appearance to the user name? Device with username, SUBSCRIBE CSS configured on User and Device?
Application users configured correctly?
Here are the steps to create a user:
1)
Got to “System”->”Licensing”->”Capabilities Assignment(s)”
Search for User XXX(example)
Enable CUP and CUPC and than save
2)
Device-> phone or Device settings-> Device Profile( for Extension mobility)
Search for Phone XXX and Enter Directory Number
Scroll down and click on Associated End Users.. Select User XXX and then Add Selected
3)
Device->Phone -> Add New … Choose phone type Cisco Unified Personal Communication and then Next
Device name: UPC+”USERNAME” in our example UPCXXX
Device Security profile and Media Resource Group list we select the appropriate
SIP profile: Standard SIP Profile
Save
Then Click on Add a New DN( directory number)
Directory number-> Enter User XXX's DN
Scroll down….Associate End users
4)
User Management -> End users
Device Associations-> Controlled Devices-> Device Association
Primary extension
Permissions Information : Add to user group: Select Standard CTI enabled
If you still have problems after these steps, do tell... (I've suffered enough with CUP to know how it feels ;) )
thaks for your reply
The presence is now comming...but i can only message to the other user..When I double click the call is not going
ie in presence the phone no: is not there...I am not integrated presence with LDAP
Any idea???
Can you send the "show server health"?
Did you add in the phone's mac address to the CTiGW application account to control this phone? Also, is the user you logged in with have CTI Enabled for security?
Green
thats the problem, phone will not be displayed unless u integrate cups with ldap. cupc doesnt have a way to obtain info from user, normal dialing should work though (using dialpad)
Can I integrate it with callmanger LDAP
Callmanager userdatabase is also LDAP right??
Is there any way...
It is not LDAP compliant. Basically, you should be able to use Remote Call Control with CUPC, but you will not see presence of other users. The reason being is that CUPS needs to have a common LDAP directory for lookup and reference. Also, do not add your account to the "Buddy List" it will only cause you issues.
196
