PRI and ATA186
I have the following problem:
100->PBX->pri->router3725-lan-router806->ata186->310
where 100 and 310 are two phone extensions
when I'm dialing from 310 to 100 the router is disconnecting with the message "Cause i = 0x82C1 - Bearer capability not implemented"
if i shutdown the dial peer 300, the call succedes, what is happening? what I'm missing?
router3725#
interface Serial1/0:15
no ip address
no logging event link-status
isdn switch-type primary-net5
isdn protocol-emulate network
isdn incoming-voice voice
isdn T310 6000
isdn bchan-number-order ascending
no cdp enable
dial-peer voice 300 voip
destination-pattern 31.
session target ipv4:10.20.10.2
dial-peer voice 100 pots
destination-pattern 1..
direct-inward-dial
port 1/0:15
forward-digits all
Thank you very much!!
1 REPLY
Re: PRI and ATA186
I made it ..it was the codec...
thanks
284
