PRI - sending digits in block?
I have a problem with sending digits between alcatel 4400 and 3660 E1 voice interface.
i.e. number 5551234
Alcatel has configureg ARS - if number starts from 555 send it to router
If Alcatel sends digits to router in order:
-555
-1
-2
-3
-4
I do not see "sending complete" msg in ISDN debug. Router connect call, all works fine. The only one problem is, when user dial 555 hears dial tone from the rouer.
I tried to send whole number in one block:
-5551234
in this situation on the router ISDN debug I see that the number has been sent in one block, after number there is "sending complete", but the router does not try to setup the connection.
is there any way to fix that?
Piotr
1 ACCEPTED SOLUTION
Re: PRI - sending digits in block?
try adding this command "direct-inward-dial" to your dial peers. by default a pri circuit is not assumed to be direct inward dial that is why you getting the second dial tone.
btw,
my D channel conf:
interface Serial6/0:15
no ip address
no logging event link-status
isdn switch-type primary-net5
isdn overlap-receiving
isdn incoming-voice voice
isdn T306 60000
isdn T310 60000
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
any chance of you dial-peers, the Serial looks OK but what else is happening?
Paul
here they are:
dial-peer voice 1 pots
destination-pattern 39..
no digit-strip
port 6/0:15
dial-peer voice 2 voip
destination-pattern 225760...
progress_ind setup enable 1
session target ipv4:10.10.1.1
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
dial-peer voice 3 pots
destination-pattern 6...
no digit-strip
port 6/0:15
forward-digits all
dial-peer voice 4 pots
destination-pattern 46........
no digit-strip
port 6/0:15
dial-peer voice 5 pots
destination-pattern 45........
no digit-strip
port 6/0:15
dial-peer voice 8 pots
destination-pattern 38..
no digit-strip
port 6/0:15
dial-peer voice 224 voip
destination-pattern 0.........
session target ras
dtmf-relay h245-alphanumeric
no vad
On one of the POTS dial peers add the statement
direct-inward-dial
that will fix the problem.
Paul
225
