PRI Signalling question
When DTMF is transmitted across a PRI, is it sent inband across the B channel as part of the voice call, or is it sent out of band across the D channel?
1 ACCEPTED SOLUTION
Blue
Re: PRI Signalling question
John,
Only call setup information goes across the D channel. After the call is connected, DTMF would be carried in band on the B channel.
You can do a debug isdn q931 on a PRI gateway router to verify this.
Please rate helpful posts.
Dave
Blue
John,
Dave
Thanks Dave. Don't tell the Cisco guys this, but it isn't plugged into a Cisco gateway, which is limiting my troubleshooting capabilities, but it's the customer requirement. But, this will certainly help point to where they need to make corrections.
I hope this is helpful, you can download a graphical PRI debugger that parses q931 debugs at pippinsoftware.com It's demo, just 10 channels, since they are still in beta testing. Could be useful for general debugging.
The full version of this is out now and it's very inexpensive.
201
