PRI T1 MGCP or H323 ? When connecting to CCM 3.2.2c
The PRi is connected to IOS 3640 gateway, I have configured several H323 gateways, with IOS 12.2.11T, the ios seems stable enough to run the PRI, I also have the HDA-FXS/FXO module which is configured via MGCP in the same router. I am running in to registration issues with the PRI, and thinking of resorting back to H323 for this T1.
TAR
Re: PRI T1 MGCP or H323 ? When connecting to CCM 3.2.2c
If you are using BRI, then it is not supported by MGCP still.
But if you are using it as PRI, then I guess it should work.
Check it out.
This works fine either way. I have had success using MGCP to control the PRI. Do you have the PRI configured for backhaul ISDN support? You need to let MGCP configure the ISDN, not the router. Sorry I don't have an example config, but there is a new tech document on CCO that covers this config along with MGCP fall-back. Fallback works fine as well, and you can now have the router pull a TFTP config for the voice functions after it boots.
The document I am refering to addresses troubleshooting for registration problems.
I use the same IOS with MGCP and E1in France, and all is working fine. Here's the configuration :
ccm-manager redundant-host X.X.X.X
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server X.X.X.X
controller E1 2/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
controller E1 2/1
framing NO-CRC4
pri-group timeslots 1-16 service mgcp
interface Serial2/0:15
no ip address
no logging event link-status
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial2/1:15
no ip address
no cdp enable
voice-port 2/0:15
voice-port 2/1:15
mgcp
mgcp call-agent X.X.X.X 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp modem passthrough voip redundancy
mgcp package-capability mf-package
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp timer net-cont-test 3000
mgcp sdp simple
mgcp profile default
dial-peer cor custom
dial-peer voice 9992015 pots
application mgcpapp
port 2/0:15
dial-peer voice 9992115 pots
application mgcpapp
port 2/1:15
Malik.
116
