PRI with NI2 between a 1760 and MRP-300
I have a lab setup with a 1760 and an MRP-300. I am trying to setup a PRI between them using NI2 protocol. I have the 1760 setup as the Network and the MRP as the User with a T1 Crossover cable between them. I have the 1760 setup with this config:
tdm clock T1 0/0 both import onboard internal
tdm clock T1 0/1 both import onboard internal
voice-card 0
isdn switch-type primary-ni
controller T1 0/1
framing esf
linecode b8zs
cablelength short 133
pri-group timeslots 1-24 service mgcp
interface Serial0/1:23
no ip address
no logging event link-status
isdn incoming-voice voice
no cdp enable
The MRP-300 is setup like this:
tdm clock T1 0/0 both export line
tdm clock T1 0/1 both import T1 0/0 line
voice-card 0
controller T1 0/0
framing esf
linecode b8zs
controller T1 0/1
framing esf
linecode b8zs
interface Serial0/0:23
no ip address
no cdp enable
no ip address
no cdp enable
voice-port 0/0:23
voice-port 0/1:23
I have the routers connect on 0/1 of the 1760 and 0/0 of the MRP-300
My problem is that I keep getting User RX <- BAD FRAME(0x00017F) on both sides of the circuit. I think the clocking is setup correctly but would like to get a second option.
Blue
Re: PRI with NI2 between a 1760 and MRP-300
Under the Serial interface of the router you want as network side you need the following command:
isdn protocol-emulate network
If that doesn't work make sure your cabling is ok.
That did it. Thanks.
199
