priority-queue out not working on 3750
Not sure what I am missing but I can't enable priority-queuing on cisco 3750
int gigabitEthernet 1/0/27
xxxxxxxxxxxxxxxx(config-if)#priority-queue out
% Invalid input detected at '^' marker.
show version
IOS (tm) C3750 Software (C3750-I5-M), Version 12.1(14)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 02-Sep-03 04:39 by antonino
Image text-base: 0x00003000, data-base: 0x008F14A0
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(11r)AX, RELEASE SOFTWARE (fc1)
sun-radiorm-3750 uptime is 6 years, 36 weeks, 1 day, 15 hours, 13 minutes
System restarted at 19:18:57 MST Wed Mar 10 2004
System image file is "flash:c3750-i5-mz.121.14-EA1a/c3750-i5-mz.121.14-EA1a.bin"
cisco WS-C3750G-24TS (PowerPC405) processor (revision C0) with 118774K/12288K bytes of memory.
Processor board ID CAT0745R0W3
Last reset from power-on
Bridging software.
4 Virtual Ethernet/IEEE 802.3  interface(s)
28 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:0E:38:D7:DE:00
Motherboard assembly number     : 73-7058-09
Power supply part number        : 341-0045-01
Motherboard serial number       : CAT074302BZ
Power supply serial number      : PHI073600D3
Model revision number           : C0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24TS-E
System serial number            : CAT0745R0W3
Switch   Ports  Model              SW Version              SW Image
*    1   28     WS-C3750G-24TS     12.1(14)EA1a            C3750-I5-M
Configuration register is 0xF
Any suggestions....
1 REPLY
Re: priority-queue out not working on 3750
Can you try an IOS upgrade?
I've many 3750 with priority queue configured without problem.
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 08:46 by yenanh
Image text-base: 0x00003000, data-base: 0x010CE290
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
WIFI-CASALECR uptime is 1 year, 8 weeks, 6 days, 19 hours, 48 minutes
System restarted at 00:46:15 METDST Mon Sep 21 2009
System image file is "flash:c3750-ipservices-mz.122-25.SEE2/c3750-ipservices-mz.122-25.SEE2.bin"
cisco WS-C3750-24TS (PowerPC405) processor (revision M0) with 118784K/12280K bytes of memory.
Processor board ID CAT1051RKQ1
9 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
Base ethernet MAC Address       : 00:1A:A2:1A:A0:00
Motherboard assembly number     : 73-9677-10
Power supply part number        : 341-0034-01
Motherboard serial number       : CAT10515CH7
Power supply serial number      : DTH1047121C
Model revision number           : M0
Model number                    : WS-C3750-24TS-E
System serial number            : CAT1051RKQ1
Top Assembly Part Number        : 800-26382-02
Top Assembly Revision Number    : D0
Version ID                      : V05
CLEI Code Number                : CNMV200CRE
Hardware Board Revision Number  : 0x01
*    1   26     WS-C3750-24TS      12.2(25)SEE2            C3750-IPSERVICES-M
This is my config:
###GLOBAL LEVEL
errdisable recovery cause all
mls qos srr-queue input priority-queue 2 bandwidth 20
mls qos srr-queue input cos-map queue 1 threshold 3  0 1 2 3 4
mls qos srr-queue input cos-map queue 2 threshold 3  5 6 7
mls qos srr-queue output cos-map queue 1 threshold 3  5 6 7
mls qos srr-queue output cos-map queue 2 threshold 3  4
mls qos srr-queue output cos-map queue 3 threshold 3  2 3
mls qos srr-queue output cos-map queue 4 threshold 3  0 1
mls qos
access-list 102 (etc.)
class-map match-all voip
  match access-group 102
policy-map voip
  class voip
   set dscp cs5
  class class-default
   set dscp default
interface FastEthernet1/0/1
description ***
switchport trunk allowed vlan 2240,2260,2270
switchport mode trunk
service-policy input voip
priority-queue out
spanning-tree portfast trunk
spanning-tree bpdufilter disable
spanning-tree bpduguard enable
1264
