Problem between SIP to H323
I am trying to configure interconnection between gateway which is using SIP and H323. Look at the diagram
non-ciscoGW------SIP--------ciscoGW1--------H323--------CiscoGW2-------PSTN
For the nonciscoGW is the SIP server. All the IP Phone will register to the SIP server. I want to enable all the IP Phones which are registerred to the SIP server to call PSTN. I was able to make it work, somehow. But after I did some changes It doesn't work anymore.FYI, all devices are in the same subnet.
Here are the configs
ciscoGW1
voice rtp send-recv
voice service voip
sip
bind all source-interface FastEthernet0
voice class codec 1
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g711alaw
codec preference 4 g711ulaw
no voice hpi capture buffer
no voice hpi capture destination
fax interface-type fax-mail
controller E1 0
pri-group timeslots 1-31
controller E1 1
clock source line secondary 1
controller E1 2
clock source line secondary 2
controller E1 3
clock source line secondary 3
gw-accounting aaa
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
clockrate 2015232
no fair-queue
interface Serial1
no ip address
shutdown
clockrate 2015232
no fair-queue
interface Serial2
no ip address
shutdown
clockrate 2015232
no fair-queue
interface Serial3
no ip address
shutdown
clockrate 2015232
no fair-queue
interface Serial0:15
no ip address
isdn switch-type primary-net5
isdn overlap-receiving T302 2000
isdn protocol-emulate network
isdn incoming-voice modem
isdn send-alerting
no isdn outgoing display-ie
no cdp enable
interface Serial3:15
no ip address
isdn switch-type primary-5ess
no cdp enable
ip address 192.168.0.159 255.255.255.0
duplex auto
speed auto
ip classless
no ip http server
voice-port 0:D
cptone SG
voice-port 3:D
dial-peer voice 2 voip
destination-pattern 9T
voice-class codec 1
session target ipv4:192.168.0.160
dtmf-relay h245-alphanumeric
no vad
sip-ua
ciscoGW2
mta receive maximum-recipients 0
interface FastEthernet0/0
ip address 192.168.0.160 255.255.255.0
speed auto
ip classless
no ip http server
call rsvp-sync
voice-port 2/0
cptone SG
voice-port 2/1
mgcp profile default
dial-peer cor custom
dial-peer voice 10 pots
port 2/0
line con 0
line aux 0
line vty 0 4
no login
end
If I do a simulation call from GW1 to GW2/PSTN. I am able to by using csim sta 9XXXXXX. But when I call from IP Phone to PSTN it doesn't work. It looks like the GW1 is unable forward the call to GW2. because when I do any debug about voice. I did not get anything..ter mon has been enabled.
.Apr 15 03:34:50.899: //82/AFBCBFE68058/CCAPI/ccCallCanGateway: cannot gateway iftype 3 to 1 for cid(82)
.Apr 15 03:34:50.899: //82/AFBCBFE68058/SSAPP:0:-1/ssaSetupPeer: setup failed rc(0)
.Apr 15 03:34:50.907: //82/AFBCBFE68058/CCAPI/cc_api_call_disconnect_done: cause=3,retry=0,vcCauseCode=0
Re: Problem between SIP to H323
It won't work. ciscoGW1 cannot translate SIP-to-H323 protocol and wise-versa. You need a SIP/H23 Gateway in this case.
SSng
I thought so before but even I change using SIP to SIP, it doesn't work either here are the changes
voice-class codec 1
session protocol sipv2
no vad
But fyi I ever made it working but I can remember what I change.it should be the same as what I pasted b4.
anyway thanks alot
-santo-
You must have a good reason to use cisoGW1 and CiscoGW2 in your scenario. Is this going be to a real case or juts a test lab.
In any case, ciscoGW cannot become a transit.
Why don't you design in such a way that sip proxy send voip call directy to voicegw2 to pstn?
Or use another SIP proxy server to act as the Directory SIP Proxy.
Something like this
IPPhone->OutboutSIPProxy(OSP)->DirectorySIPProxy(DSP)->VGW->PSTN
You can have many OSP to serve different domains. A a pair of DSP for redundancy. And many VGW to serve other PSTN connections
Use the VGW only as VOIP-to-PSTN at edge of your network.
for some reasons the router must be setup like that. The protocol between the cisco gateways can be either sip or h323.
many thanks
-santo-
Santo,
Just curious. What is the purpose of such a setup?
-Naren
hi,
the diagram
SIP Server----ciscoGW1-------ciscoGW2------PSTN
SIP server only supports g711 codec. ciscogw2 is not under mycontrol and only supports g729. So I use ciscoGW1 to do transcodec. I hope that the voice path will be from sip server to ciscoGW1 then to ciscoGW2. is that posssible ?
thanks
264
