Problem Call From CCM to CME
We have integrate our Cisco Call Manager with a remote Cisco Call Manager Express.
The calls from CME to CCM have no problem at the contrary we can not make a call from CCM to CME.
The integration was made by an intercluster trunk no gatekeeper controlled on CCM, here attacched I put the CME configuration.
If I open the debug on CME I have these output when I make a call from CCM directed to CME.
Nov 1 01:24:28: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 0 Event 0x1
Nov 1 01:24:28: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data:
data_mode=0x10082
Nov 1 01:24:28: //-1/xxxxxxxxxxxx/H323/cch323_get_new_ccb: ccb (0x44E34A9C) is in use
Nov 1 01:24:43: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_H225_CONNECTION_TIMER] expired
Nov 1 01:24:43: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 2
Nov 1 01:24:43: //-1/xxxxxxxxxxxx/H323/h323_set_cc_cause_for_spi_err:
Categorized cause:38, category:186
Nov 1 01:24:43: //-1/xxxxxxxxxxxx/H323/h323_set_release_source_for_peer: ownCallId[-1], src[6]
Nov 1 01:24:43: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
Nov 1 01:24:43: //-1/xxxxxxxxxxxx/H323/cch323_cleanup_xport: IP_entry is NULL, returning
Thank you
Super Bronze
Re: Problem Call From CCM to CME
Hi Laura
Have you followed the steps required on the CallManager side as outlined in this document:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a008044751b.html#wp1045089
Hope this helps..
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I followed these step:
http://www.cisco.com/univercd/cc/td/doc/product/voice/its/cme33/cme33sa/cme33bsc.htm#wp1001000
It explain in detail how to integrate CCM and CME.
354
