06-30-2003 07:13 AM - edited 03-13-2019 12:31 AM
Hi all
I have a Cisco ATA 186, but in the voice ports FXS , I do not have telefonico tone.
This is normal or I must change to something parametro in the equipment to have tone of the telefonico..
Solved! Go to Solution.
07-01-2003 03:35 PM
You need to configure the UID on the ATA otherwise you will not have dialtone
07-01-2003 08:06 AM
There are only 2 ringtones, US and Swedish. What you hear is normal. In the later releases the development might more ring types.
07-01-2003 10:09 AM
my problem is that when I connect I telephone I do not listen to ningun Dialtone.....
This behavior of the equipment is normal? ???
07-01-2003 03:35 PM
07-02-2003 05:34 AM
Thanks ,
The cisco ATA 186 O.k.
