Problem Cisco ATA 186
Hi all
I have a Cisco ATA 186, but in the voice ports FXS , I do not have telefonico tone.
This is normal or I must change to something parametro in the equipment to have tone of the telefonico..
1 ACCEPTED SOLUTION
Silver
Re: Problem Cisco ATA 186
You need to configure the UID on the ATA otherwise you will not have dialtone
There are only 2 ringtones, US and Swedish. What you hear is normal. In the later releases the development might more ring types.
my problem is that when I connect I telephone I do not listen to ningun Dialtone.....
This behavior of the equipment is normal? ???
Silver
Thanks ,
The cisco ATA 186 O.k.
150
