Community Member
PROBLEM: CUE Administration over EzVPN
Hello All,
I currently have an 1861 w/ CME and CUE.
Vlan 2 is voice
Vlan 3 is data
EzVPN Remote (NEM)
Scenario 1: VPN is NOT active
When any pc attempts to browse to the CUE administration page, it will not load.
However, when I remove the 'crypto ipsec client ezvpn BGAN inside' syntax from the vlan 3 SVI the PC can ping 10.15.13.2 and thus the administration page will load.
Scenario 2: VPN IS active
CUE administration page will load normally and I do not have to remove any syntax.
I opened two TAC service requests and neither agent is aware of a known bug which is not helpful for me, so I am hoping to get feedback from somebody on this forum that has experienced the same issue.
Below you will find a snippet of the config.
Thanks again for the help!
NOTE: CUE is working and vmails can be left, I just cant hit the administration page.
I wonder if a PBR policy will fix this issue.
interface Integrated-Service-Engine0/0
ip address 10.15.13.1 255.255.255.252
service-module ip address 10.15.13.2 255.255.255.252
service-module ip default-gateway 10.15.13.1
interface Vlan2
ip address 10.15.13.129 255.255.255.128
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.15.13.129
interface Vlan3
ip address 10.15.13.65 255.255.255.224
ip route 10.15.13.2 255.255.255.255 Integrated-Service-Engine0/0
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
interface FastEthernet0/0
description Internet
ip address x.x.x.x x.x.x.x.x
duplex auto
speed auto
crypto ipsec df-bit clear
1 REPLY
Community Member
Re: PROBLEM: CUE Administration over EzVPN
figures, no response!
134
