Community Member
Problem Dialing International From 7935
dialing international number, 011XXXXXXXXXXX, from 7935 returns Telco message :Not Enough Digits:. dialing same number from 7960 and call goes through fine.
We dial 9 for outside line and it is discarded at the gateway. Both calls pointed to the same gateway. check CSS and Partitions on both phones and they were correct. I doubt it is a gateway issue, because both calls would have failed. My guess is that there is something with the 7935 the is preventing the last digit from passing... Any ideas???
1 REPLY
Community Member
Re: Problem Dialing International From 7935
I believe this is a known issue, you cannot pass more than 11 digits fron the 7935. We have run into this with all of our 7935's (around 20)
I'll try to find the bug id and post it.
Tim Medley CCNP+Voice, CCDP
Sr. Network Architect
VoIP Group
iReadyWorld
115
