problem for receive some call
some call was not processing by the GW ( h323).
We have this trace during problem:
Sep 5 08:44:02.640: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x2076
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98383
Exclusive, Channel 3
Called Party Number i = 0x81, '4256'
Plan:ISDN, Type:Unknown
Sep 5 08:44:02.648: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xA076
Sep 5 08:44:22.701: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x2076
Cause i = 0x87EF - Protocol error; unspecified
Sep 5 08:44:22.705: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA076
Do you have mode detail about cause i = 0x87EF ??
in this trace, we do not have " Calling Party nu?ber", is it a problem ???
please found in attach the configuration ?
thanks for your help
Hall of Fame Super Gold
Re: problem for receive some call
Sebastian,
most likely, the switch is releasing the call because 20 seconds have elapsed after router sends call_proc, and not no further progress is made, like alerting.
Where the call to 4256 is supposed to go? Whatever it is, should not take 20 seconds to report either alerting, connect, or something.
Hi thanks for this update.
We have two sites (A and B) manage with the same callmanger. The callmanger was located on site A.
When we make this call, we have the problem => phone (site A) -- GW--- PSTN --- GW ---phone (site B).
When we try to joint the site B from another site or whit mobile phone, all is OK.
We have only the problem when site A calls site B. No problem when the site B calls the site A.
This problem can be like to the provider or configuration of GW???
Sebastien
Sebastien,
It seems like you are in a loop. Check your translations, and route patterns. Some where in A you have a pattern when dialed it goes direct to site B. When you try that from B it points back to B and forms a loop is my guess.
Good luck.
Rate if it helps.
Baseer.
248
