Community Member
Problem incoming call ( VG200+E1 )
I have a vg200 gateway ( h.323 gateway ).
I can't receive a call from a external phone, but I can call a external phone number.
From a other IP Phone, there is no problem ( incoming and outcoming calls ).
It's just when you dial the complet phone number from the external.
Thanks for your help.
Casta
1 REPLY
Re: Problem incoming call ( VG200+E1 )
Casta,
Sounds like you've not configured the gateway correctly.
You have not given enough info to diagnose the problem to any depth but you need to look at the dial-peer configuration on the gateway for incoming calls, how many digits are you receiving from the carrier and does your dial-peer match this.
Do you need a translation on the call manager for the incoming calls.
You need to start at the begining and work your way from there.
Paul
103
