Problem with 3640 for VoIP
Hi all,
I have a big problem to risolve with a router 3640-A .
i have a voip designe where in the remote office i have a 2610 with 2 voice E&M and a wic-1T . the serial on this router go to the central office between a dedicate line ( 64 Kbps) wiith PPP.
In the central Office i have a 2610 that has a wic-1T to connect with remote office and a 2610 that has 2 voice port (E&M) for voip .
In this case the Voip work correct.
I've tried to change the 2610 (that has the voice ports) in the central office with a 3640-A but doesn't work correctly.
After a lot of test, i put a sniffer to see why with the 3640 doesn't work and I notice that the H225 work correct but when the release complete ...RTP packet are sending out only from the remote 2610 ...while 3640 doesn't send no rtp packet.
the configuration of 3640 are the same of 2610 in the first case.
I tried to change the 3640 with an other and i tried to change also IOS fram 12.2 to 12.1 and 12.0 but is the same.
what I have to do ?? Do I have to configured the 3640 different from a 2600 ?
thanx a lot.
if you need the configuration I'm very happy to send you.
Silver
Re: Problem with 3640 for VoIP
He had a similar problem and it was resolved using the "voice rtp send-recv" global configuration command. Try it.
thanx a lot for the answer btu it doesn't work .... do you have an other possibly solution?
Marco
this is the output of my call when i digit the number... and when im listening there is a big strange noise :
1w6d: cc_api_call_setup_ind (vdbPtr=0x62159B10,
callInfo={called=,called_oct3=0x81,calling=,calling_oct3=0x0,calling_oct3a=0x0,calling_xlated=false,subscriber_type_str=RegularLine,fdest=0,pee
r_tag=41, prog_ind=3,callingIE_present 0},callID=0x61F0A624)
1w6d: cc_api_call_setup_ind calling number is null, answer addr dest pattern 4.. e164_ans_addr 0 e164_dest_pattern 0
1w6d: cc_api_call_setup_ind type 1 , prot 0
1w6d: cc_process_call_setup_ind (event=0x62136484)
1w6d: >>>>CCAPI handed cid 14 with tag 41 to app "DEFAULT"
1w6d: sess_appl: ev(24=CC_EV_CALL_SETUP_IND), cid(14), disp(0)
1w6d: sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(14), disp(0)
1w6d: ssaCallSetupInd
1w6d: ccCallSetContext (callID=0xE, context=0x622841C8)
1w6d: ssaCallSetupInd cid(14), st(SSA_CS_MAPPING),oldst(0), ev(24)ev->e.evCallSetupInd.nCallInfo.finalDestFlag = 0
1w6d: ccCallSetupAck (callID=0xE)
1w6d: ccGenerateTone (callID=0xE tone=8)
1w6d: ccCallReportDigits (callID=0xE, enable=0x1)
1w6d: cc_api_call_report_digits_done (vdbPtr=0x62159B10, callID=0xE, disp=0)
1w6d: sess_appl: ev(53=CC_EV_CALL_REPORT_DIGITS_DONE), cid(14), disp(0)
1w6d: cid(14)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(0)
1w6d: ssaReportDigitsDone cid(14) peer list: (empty)
1w6d: ssaReportDigitsDone callid=14 Enable succeeded
1w6d: cc_api_call_digit_begin (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0xE,
digit=9, digit_begin_flags=0x1, rtp_timestamp=0xFB5A669B
rtp_expiration=0x0, dest_mask=0x1)
1w6d: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(14), disp(0)
1w6d: cid(14)st(SSA_CS_MAPPING)ev(SSA_EV_DIGIT_BEGIN)
1w6d: ssaIgnore cid(14), st(SSA_CS_MAPPING),oldst(0), ev(10)
1w6d: cc_api_call_digit_end (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0xE,
digit=9,duration=85,xruleCallingTag=0,xruleCalledTag=0, dest_mask=0x1), digit_tone_mode=0
1w6d: sess_appl: ev(9=CC_EV_CALL_DIGIT_END), cid(14), disp(0)
1w6d: cid(14)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_DIGIT)
1w6d: ssaDigit
1w6d: ssaDigit, 0. sct->digit , sct->digit len 0, usrDigit 9, digit_tone_mode=0
1w6d: ssaDigit,1. callinfo.called , digit 9, callinfo.calling , xrulecallingtag 0, xrulecalledtag 0
1w6d: ssaDigit, 7. callinfo.calling , sct->digit 9, result 1
digit=0, digit_begin_flags=0x1, rtp_timestamp=0xFB5A669B
digit=0,duration=85,xruleCallingTag=0,xruleCalledTag=0, dest_mask=0x1), digit_tone_mode=0
1w6d: ssaDigit
1w6d: ssaDigit, 0. sct->digit 9, sct->digit len 1, usrDigit 0, digit_tone_mode=0
1w6d: ssaDigit,1. callinfo.called , digit 90, callinfo.calling , xrulecallingtag 0, xrulecalledtag 0
1w6d: ssaDigit, 7. callinfo.calling , sct->digit 90, result 1
digit=2, digit_begin_flags=0x1, rtp_timestamp=0xFB5A669B
digit=2,duration=85,xruleCallingTag=0,xruleCalledTag=0, dest_mask=0x1), digit_tone_mode=0
1w6d: ssaDigit
1w6d: ssaDigit, 0. sct->digit 90, sct->digit len 2, usrDigit 2, digit_tone_mode=0
1w6d: ssaDigit,1. callinfo.called , digit 902, callinfo.calling , xrulecallingtag 0, xrulecalledtag 0
1w6d: ssaDigit, 7. callinfo.calling , sct->digit 902, result 0
1w6d: ccCallReportDigits (callID=0xE, enable=0x0)
1w6d: ssaSetupPeer cid(14) peer list: tag(9) called number (902)
1w6d: ssaSetupPeer cid(14), destPat(902), matched(1), prefix(), peer(622E7C88), peer->encapType (2)
1w6d: ccCallProceeding (callID=0xE, prog_ind=0x0)
1w6d: ccCallSetupRequest (Inbound call = 0xE, outbound peer =9, dest=, params=0x6213A478 mode=0, *callID=0x6213A7E8, prog_ind = 3)
callingIE_present 0
1w6d: ccCallSetupRequest numbering_type 0x81
1w6d: ccCallSetupRequest encapType 2 clid_restrict_disable 1 null_orig_clg 1 clid_transparent 0 callingNumber
continue
1w6d: dest pattern 9.., called 902, digit_strip 0
1w6d: callingNumber=, calledNumber=902, redirectNumber= display_info= calling_oct3a=0
1w6d: accountNumber=, finalDestFlag=0,
guid=d105.5b66.1fb9.11cc.8020.86a6.dc3e.92b1
1w6d: peer_tag=9
1w6d: ccIFCallSetupRequestPrivate: (vdbPtr=0x620D84FC, dest=, callParams={called=902,called_oct3=0x81, calling=,calling_oct3=0x0,
calling_xlated=false, subscriber_type_str=RegularLine, fdest=0, voice_peer_tag=9},mode=0x0) vdbPtr type = 1
1w6d: ccIFCallSetupRequestPrivate: (vdbPtr=0x620D84FC, dest=, callParams={called=902, called_oct3 0x81, calling=,calling_oct3 0x0,
calling_xlated=false, fdest=0, voice_peer_tag=9}, mode=0x0, xltrc=-5)
1w6d: ccSaveDialpeerTag (callID=0xE, dialpeer_tag=0x9)
1w6d: ccCallSetContext (callID=0xF, context=0x622A6948)
1w6d: cid(14)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
1w6d: -cid2(15)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
1w6d: ssaReportDigitsDone callid=14 Reporting disabled.
1w6d: cc_api_call_alert(vdbPtr=0x620D84FC, callID=0xF, prog_ind=0x8, sig_ind=0x1)
1w6d: sess_appl: ev(7=CC_EV_CALL_ALERT), cid(15), disp(0)
1w6d: cid(15)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_ALERT)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(0)fDest(0)
1w6d: -cid2(14)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
1w6d: ssaAlert
1w6d: ccGetDialpeerTag (callID=0xE)
1w6d: ccCallAlert (callID=0xE, prog_ind=0x8, sig_ind=0x1)
1w6d: ccConferenceCreate (confID=0x6213ABBC, callID1=0xE, callID2=0xF, tag=0x0)
1w6d: cc_api_bridge_done (confID=0x7, srcIF=0x620D84FC, srcCallID=0xF, dstCallID=0xE, disposition=0, tag=0x0)
1w6d: cc_api_bridge_done (confID=0x7, srcIF=0x62159B10, srcCallID=0xE, dstCallID=0xF, disposition=0, tag=0x0)
1w6d: cc_api_caps_ind (dstVdbPtr=0x620D84FC, dstCallId=0xF, srcCallId=0xE,
caps={codec=0x2EBFB, fax_rate=0x7F, vad=0x3, modem=0x2
codec_bytes=0, signal_type=3})
1w6d: cc_api_caps_ind (Playout: mode 0, initial 60,min 40, max 200)
1w6d: sess_appl: ev(29=CC_EV_CONF_CREATE_DONE), cid(14), disp(0)
1w6d: cid(14)st(SSA_CS_CONFERENCING_ALERT)ev(SSA_EV_CONF_CREATE_DONE)
oldst(SSA_CS_CALL_SETTING)cfid(7)csize(0)in(1)fDest(0)
1w6d: -cid2(15)st2(SSA_CS_CONFERENCING_ALERT)oldst2(SSA_CS_CALL_SETTING)
1w6d: ssaConfCreateDoneAlert
1w6d: cc_process_notify_bridge_done (event=0x6212FC80)
1w6d: cc_api_caps_ind (dstVdbPtr=0x62159B10, dstCallId=0xE, srcCallId=0xF,
caps={codec=0x4, fax_rate=0x2, vad=0x2, modem=0x0
codec_bytes=20, signal_type=2})
1w6d: cc_api_caps_ack (dstVdbPtr=0x62159B10, dstCallId=0xE, srcCallId=0xF,
codec_bytes=20, signal_type=2, seq_num_start=8699})
1w6d: cc_api_caps_ack (dstVdbPtr=0x620D84FC, dstCallId=0xF, srcCallId=0xE,
1w6d: cc_api_voice_mode_event , callID=0xE
1w6d: Call Pointer =622841C8
1w6d: sess_appl: ev(51=CC_EV_VOICE_MODE_DONE), cid(14), disp(0)
1w6d: cid(14)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_VOICE_MODE_DONE)
oldst(SSA_CS_CONFERENCING_ALERT)cfid(7)csize(0)in(1)fDest(0)
1w6d: -cid2(15)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CALL_SETTING)
1w6d: ssaIgnore cid(14), st(SSA_CS_CONFERENCED_ALERT),oldst(4), ev(51)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(7)csize(0)in(1)fDest(0)
1w6d: cc_api_call_disconnected(vdbPtr=0x62159B10, callID=0xE, cause=0x10)
1w6d: sess_appl: ev(11=CC_EV_CALL_DISCONNECTED), cid(14), disp(0)
1w6d: cid(14)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_DISCONNECTED)
1w6d: ssaDisconnectedAlert
1w6d: ssaDisconnectedAlert: redirect_numbers(0)
1w6d: ssaFlushPeerTagQueue cid(14) peer list: (empty)
1w6d: ccConferenceDestroy (confID=0x7, tag=0x0)
1w6d: cc_api_bridge_drop_done (confID=0x7, srcIF=0x620D84FC, srcCallID=0xF, dstCallID=0xE, disposition=0 tag=0x0)
1w6d: cc_api_bridge_drop_done (confID=0x7, srcIF=0x62159B10, srcCallID=0xE, dstCallID=0xF, disposition=0 tag=0x0)
1w6d: sess_appl: ev(30=CC_EV_CONF_DESTROY_DONE), cid(14), disp(0)
1w6d: cid(14)st(SSA_CS_CONF_DESTROYING)ev(SSA_EV_CONF_DESTROY_DONE)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(-1)csize(0)in(1)fDest(0)
1w6d: -cid2(15)st2(SSA_CS_CONF_DESTROYING)oldst2(SSA_CS_CALL_SETTING)
1w6d: ssaConfDestroyDone
1w6d: ccCallDisconnect (callID=0xE, cause=0x10 tag=0x0)
1w6d: ccCallDisconnect: existing_cause = 0x0, new_cause = 0x10
1w6d: ccCallDisconnect (callID=0xF, cause=0x10 tag=0x0)
1w6d: cc_api_call_disconnect_done(vdbPtr=0x62159B10, callID=0xE, disp=0, tag=0x0)
1w6d: sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(14), disp(0)
1w6d: cid(14)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_CONF_DESTROYING)cfid(-1)csize(0)in(1)fDest(0)
2610_Voice_Roteglia#
2610_Voice_Roteglia#S_DISCONNECTING)oldst2(SSA_CS_CALL_SETTING)
1w6d: ssaDisconnectDone
1w6d: cc_api_icpif: expect factor = 0
1w6d: cc_api_call_disconnect_done(vdbPtr=0x620D84FC, callID=0xF, disp=0, tag=0x0)
1w6d: sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(15), disp(0)
1w6d: cid(15)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_CALL_SETTING)cfid(-1)csize(1)in(0)fDest(0)
1w6d: :rtp_udp_unreachable:Entered: ICMP unreachable for dest port16503
Silver
Can you post a "show version" command at the 3600?, do you have enough DRAM memory at your router?, have you tried another IOS version?
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(13a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Sun 02-Feb-03 13:07 by kellythw
Image text-base: 0x60008930, data-base: 0x61122000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
3640_Roteglia uptime is 4 hours, 37 minutes
System image file is "flash:c3640-is-mz.122-13a.bin"
cisco 3640 (R4700) processor (revision 0x00) with 60416K/5120K bytes of memory.
Processor board ID 22785426
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
1 FastEthernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
8 Voice E & M interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Silver
What ip address is sent at the in the h225 call setup?, Is this address reachable from your router?
yes is reachable..... infact the h225 call setup release is complete ..but the 3640 doesn't generate out RTP packet.. and the configuration is the samen that i put on 2610 ( and it works) ..
if you want i can send you the 2 configuration.
Silver
Hum, it's a very strange problem.
Yes, you can send me the 2 config to the next mail address:
icabrera11@hotmail.com
195
