Community Member
problem with an EVM-HD 8FXS/DID module
Hi all,
I have a 2821 router with the IOS Version 12.4(3f)
When the router starts the 2 EM-HDA-6FXO cards which are plugged on the EVM-HD-8FXS/DID module are ligthening but in the running configuration I can not see the voice ports.
Please can someone help me activate these voice ports ?
In attached are the results of the show diag and sh ver commands.
1 ACCEPTED SOLUTION
VIP Purple
Re: problem with an EVM-HD 8FXS/DID module
Do you have DSP resources available for these cards? You will need PVDM2s. DSP resources are necessary for the ports to show up in your config.
Hope this helps. If so, please rate the post.
Brandon
1 REPLY
VIP Purple
Brandon
170
