11-22-2005 05:59 AM - edited 03-13-2019 11:19 AM
Hi all,
I have a problem with a CME, I put a telephone on remote site, and I create a VPN between 2811 (with CME) and 837 (on remote site) and it's ok, the telephone go on and register on CME, it can call the other telephones and use voicemail etc, but when it call a PSTN number, the telephone IP user can not listen what say the PSTN telephone user. Do you can help me, or suggest how to resolve the item?
Thank you very much.
Bye
A.
11-24-2005 11:33 AM
What are you using to access PSTN? BRI? PRI? What IOS /CME versions?
11-25-2005 12:14 AM
I use tow BRI and the CME version is 3.2, but I have resolved my problem. Seems that CME v3 does not support (ufficialy) remote telephone, but is supported from CME v4.
I resolve using a GRE tunnel instead Peer-to-peer VPN, with this tunnel the remote telephone works fine!
Thank you
A.
11-25-2005 01:16 PM
Cool, if you really want encryption you could do IPSec over GRE - I've done this and it does work with 3.2/3
Personally I except the voice from encryption, because I don't really see the point.
p.
