Community Member
Problem with configuring IP Communicator. TFTP edit control is inactive.
Hello all,
I have a very strange problem with ip communicator. I've setup ip communicator successfully. Then I want to setup it. I open preferences and I see that TFTP server edit control in inactive. So I can't to set our tftp server. So ip communicator isn't register on cucm.
I've checked 2.1.2 and 7.0.1 versions.
I've attached preference window to post.
P.S.: I've tried to set tftp server via command line options (msiexec ipc.msi bla bla bla). It isn't working same.
What I need to do to fix this problem?
Bronze
Re: Problem with configuring IP Communicator. TFTP edit control
Very strange problem, did you try to reinstall the CIPC?
Best regards
David
Community Member
Yes. Four or five times. It isn't helps to me.
Are there entries in the registry?
[HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\Communicator]
"NetworkCurrentAdapter"=""
"HostName"="SEP000000000000"
Hkey_Current_User\Software\Cisco Systems, Inc\Communicator
are you using a full access account when installing the IPC?
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
"NetworkCurrentAdapter"="Intel(R) PRO/Wireless 3945ABG Network Connection - Paketplaner-Miniport"
"HostName"="SEP0013A98A5F89"
in hkey_current_user there are not entries set
When I installing the IPC I use account with Local Administrator permissions.
Community Member
hi! is there any progress?
I just installed ver 2.1.3 on my home PC WinXP and I had the SAME problem!
I have installed IPC a few times but I can't set tftp server IP: all greyed out!
Community Member
I had the same problem with CIPC v7.06 & windows 7
In the end i tried to run the CIPC as adminsitrator and then i could edit all the fields.
Community Member
If you simply run as administrator (Ctrl + Right Click on the application then select Run as Admin), you have full access to required parameters.
5548
