Problem with Dialogic Card dominating ports
We have for some time had all 12 of our dialogic card ports answering PBX callas and 4 licensed ports answering call manager calls.
We recently reduced the number of ports configured to answer PBX caalls on the dialogic board via unity admin to 8.
Ports 9-16 were, in turn, assigned to clal manager and assigned the correct extensions. All of this was done after the call manager VM ports had been correctly updated for this, and the TSP updated to reflect the new ports and Unity restarted.
Unity admin correctly reflects that ports 1-8 are pBX serial integration ports and 9-16 are clal manager ports, however - when a call comes into the first call manager port - it still comes into port 13.
And the extensions assigned to ports 8-12 do not answer call manager calls - but continue to respond if we manually dial the numbers of the ports going into the dialogic card.
So it seems that dialogic isn't letting go of these ports? Is there something we can do more correctly to fix this?
I was also going to open a TAC case if this is too complex - but it seemed liek it might be a no-brainer error I made with the change so thought I'd ask first :-)
Ken Johnson
Mgr. Network Services
LeTourneau University
CIPTUG
Cisco IP Telephony Users Group
http://www.ciptug.org
1 ACCEPTED SOLUTION
Re: Problem with Dialogic Card dominating ports
You haven't specified the version of Unity being used but I suspect it is pre-4.x. In that case, yes, Unity will first by default grab all of the voice ports offered by the Dialogic TSP. To account for this, you can follow the proceedure "Assigning Dialogic Ports for a Dual Phone System Integration", found in each Integration Guide. For example, see...
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity31/integuid/centsmdi/centx312/itappxc.htm
Eric
Eric
Thanks! As you suspected we are on 3.1(5) - sadly - though with enough free time we'll eventually make the good jump to 4 :-)
That article sounded just right - I tried it - and success!
Thanks!
- Ken
228
