Problem with Fax and ATA
i do not have problem to send Fax to the PSTN, but when I try to receive a fax on the fax machine in port1 of the ATA, the machine never give fax signal.
1 REPLY
Hall of Fame Super Red
Re: Problem with Fax and ATA
Hi Leonardo,
Have a look at the following;
Cisco ATA 186 and Cisco ATA 188 Analog Telephone Adaptor Administrator's Guide (SCCP) (2.15.ms, Rev B0)
Configuring and Debugging Fax Services
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_administration_guide_chapter09186a00800c4d1e.html#1016012
Configuring and Troubleshooting the Cisco ATA 186 with Fax
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a00800d698e.shtml
Configure Fax Detection Method on the Cisco ATA 186
Use a web browser and go to http:///dev (for example, http://172.16.104.117/dev) in order to configure the Cisco ATA 186 using the web interface.
You must configure these parameters in order to configure the Cisco ATA 186.
Audio Mode
bit 2 (18)=0 Enable detection of FAX CED (answer) tone and switch to FAX mode for the rest of the call if the tone is detected.
Hope this helps!
Rob
441
