Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
problem with incoming calls
I have got E1 trunk, CCME, I can dial-out for eternal numbers, but I cannot dial-in to internal phones, my config looks like:
card type e1 0 0
isdn switch-type primary-net5
voip-incoming translation-rule called 1
controller E1 0/0/0
pri-group timeslots 1-31
translation-rule 1
Rule 0 ^2232195 5
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
no cdp enable
dial-peer voice 100 pots
destination-pattern 0T
port 0/0/0:15
dial-peer voice 10 pots
incoming called-number 223219...
direct-inward-dial
port 0/0/0:15
telephony-service
load 7912 P00307020200
max-ephones 48
max-dn 96
ip source-address 10.48.4.1 port 2000
url services http://10.48.4.2/voiceview/common/login.do
url authentication http://10.48.4.2/voiceview/authentication/authenticate.do
time-format 24
date-format dd-mm-yy
create cnf-files version-stamp 7960 Oct 13 2006 11:46:09
voicemail 2369
max-conferences 8 gain -6
dn-webedit
time-webedit
ephone-dn 1 dual-line
number 540
ephone 1
mac-address 0019.0644.5D07
button 1:1
what am I doing wrong?
also, when I am dialing-outfrom any number it is presented outside with first number... :-(
but my main question is what to do to successfully dial-in?
regards
Slawek
Re: problem with incoming calls
i had a similar problem but the experts here successfully guided me in creating a voice translational rule.
Can you let me know the number & Digits the service provider is going to forward it to you.
Narayan
My service provider is sending 9 digits, for example 223219540, internal nuber is 540 (I can see it when ISDN debug is turned on), without 0 at the beginning
regards
Slawek
I have added to telephone-service line:
dialplan-pattern 1 2233195.. extension length 3 extension-pattern 5..
and it WORKS now!
I can connect to my VoIP phones, but I cannot connect to my VIC 4FXS card...
config is like:
voice-port 0/1/0
station-id number 560
dial-peer voice 560 pots
destination-pattern 560
port 0/1/0
what should I add in my config ???
please help... my time is ending :-(
regards
Slawek
I think that the telco sends digits by overlap method...
Add the configuration below,
int serial0/0/0:15
isdn overlap-receving
and test!
119
