Problem with incoming PSTN call routing
Hello there! I'm new to the Cisco IP telephony world, and am trying to get my head around how it all works. I have a nearly-running system at the moment - just one obstacle left.
We have a Cisco 2811 ISR running CCME 3.3. The router is connected to two ISDN BRI lines, and it serves some Cisco IP phones. Whenever an incoming call comes in from the PSTN, the caller will get a dial tone. If they then key in the extension number, it will connect them to the correct phone. Despite trying many things, I cannot get the router to look at the incoming called number, and to route it to the correct extension automatically. The ISDN service has 20 DDI numbers allocated to it.
I have set up the following dial-peers:
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 2 pots
direct-inward-dial
dial-peer voice 11 pots
destination-pattern .T
port 0/0/0
dial-peer voice 12 pots
port 0/0/1
I have also tried putting port 0/0/0 and 0/0/1 into dial-peers 1 and 2, to no effect.
The only other line of interest (perhaps) is an entry in the telephony-service section:
dialplan-pattern 1 01234567... extension-length 3
The phone extensions we use are 8..
I'm obviously doing something silly, but after a whole week of struggling with this, can't work out where I'm going wrong.
Does anyone have any pointers?
As a small aside, how do I set the router up so that groups of ephone-dns have the same Caller ID? Say, for instance, I would like extensions 800-809 to show a Caller ID of 01234567800, and for extensions 810-819 to show a Caller ID of 01234567810... - would this be possible?
Hall of Fame Super Silver
Re: Problem with incoming PSTN call routing
Add "port 0/0/0" to dial-peer 1 and "port 0/0/1" to dial peer 2.
Chris
Thanks for the reply. As mentioned in my original post, this doesn't work for some reason (although I would have thought it did).
If I enter these into dial-peer 1 and 2, then it causes the router to hang up the call immediately. If I leave them out of dial-peer 1 and 2, then I get presented with the dial tone, and keying in the three digit extension number will then route my call...
Any ideas where it's going wrong?
Silver
This is strange...
Can you place a test call and while the call is active do a "show call active voice brief". This will tell you which dial-peer the call is matching and lets see if there is something else that is happening. Please post the output of the command.
Anup
Silver
Regarding the caller-id, you can use Translation rules to make it happen.
1. Create a translation rule to change 800-809 to 01234567800 and 810-819 to 01234567810
voice translation-rule 1
rule 1 /^80./ /01234567800/
rule 2 /^81./ /01234567810/
2. Create a translation profile to change the calling numbers
voice translation-profile ANI
translate calling 1
3. Apply the translation profile to the dial-peers
port 0/0/0
translation-profile outgoing ANI
port 0/0/1
Anup
Hello Anup
Thanks for the feedback. In terms of receiving a call originating from a POTS connection, the following result is displayed:
CIS2811#show call active voice brief
: hs. + pid:
dur hh:mm:ss tx:/ rx:/
IP : rtt:
delay://ms
media inactive detected: media cntrl rcvd: timestamp:
MODEMPASS buf:/ loss /
last s dur:/s
FR [int dlci cid] vad: dtmf: seq:
(payload size)
ATM [int vpi/vci cid] vad: dtmf: seq:
(payload size)
Tele (callID) [channel_id] tx://ms noise: acom:
> i/o:/ dBm
MODEMRELAY info:// xid:/ total://<
drops>
speeds(bps): local / remote /
Proxy :
anf>
bw: / codec:
tx:
tes>
rx:
es>
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 1
1248 : 394 436796580ms.1 +-1 pid:12 Answer connected
dur 00:00:00 tx:0/0 rx:0/0
Tele 0/0/1 (394) [0/0/1.1] tx:0/0/0ms None noise:0 acom:0 i/0:0/0 dBm
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 1
If the extension is dialled after the caller hears the dial tone (in this case, extension 876), the following is output:
: hs. + pid:
IP : rtt:
delay://ms
last s dur:/s
(payload size)
(payload size)
> i/o:/ dBm
drops>
Proxy :
anf>
bw: / codec:
tx:
tes>
rx:
es>
Telephony call-legs: 2
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
1249 : 395 436889270ms.1 +-1 pid:12 Answer connected
Tele 0/0/1 (395) [0/0/1.2] tx:0/0/0ms None noise:0 acom:0 i/0:0/0 dBm
1249 : 396 436892410ms.1 +-1 pid:20005 Originate 876 connecting
Tele 50/0/7 (396) [50/0/7.0] tx:0/0/0ms None noise:0 acom:0 i/0:0/0 dBm
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
Any input you may have would be most welcome. Many thanks! Also - thanks for posting details on how to use translation rules to specify a Caller ID.
To follow up from my last post, I have listed below the running-config output of the router in question:
CIS2811#show conf
Using 4942 out of 245752 bytes
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service sequence-numbers
hostname CIS2811
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret 5 [snip]
no aaa new-model
resource policy
clock timezone gmt 0
clock summer-time GMT recurring
network-clock-participate wic 0
ip subnet-zero
ip tcp synwait-time 10
ip cef
ip domain name [snip].com
ip name-server 192.168.16.2
ip ssh time-out 60
ip ssh authentication-retries 2
isdn switch-type basic-net3
voice-card 0
no dspfarm
voice class codec 1
codec preference 2 g711alaw
crypto pki [snip]
! [SNIP] !
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$$ES_LAN$$FW_INSIDE$$ETH-LAN$
ip address 192.168.16.222 255.255.255.0
ip route-cache flow
duplex auto
speed auto
interface FastEthernet0/1
no ip address
ip route-cache flow
shutdown
duplex auto
speed auto
interface BRI0/0/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
isdn skipsend-idverify
interface BRI0/0/1
no ip address
isdn static-tei 0
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
no logging trap
tftp-server flash:CP7912060000SCCP050124A.sbin
control-plane
voice-port 0/0/0
compand-type a-law
cptone GB
voice-port 0/0/1
compand-type a-law
cptone GB
direct-inward-dial
direct-inward-dial
port 0/0/0
port 0/0/1
telephony-service
load 7912 CP7912060000SCCP050124A
max-ephones 15
max-dn 50
ip source-address 192.168.16.222 port 2000
network-locale GB
time-zone 21
time-format 24
date-format dd-mm-yy
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 8 gain -6
moh music-on-hold.au
web admin system name [snip] password [snip]
dn-webedit
time-webedit
transfer-system full-consult
ephone-dn 1 dual-line
number 890
label Conference 1
name Conference 1
![ephone-dn snip] !
ephone 1
mac-address 0001.0001.0001
type 7912
button 1c1
! [ephone snip]
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 192.168.16.2
end
put direct-inward-dial on your out going dial peers and this should help ie the POTS dial peer thats associated with the voice ports
Hello!
Thanks for that. I have added "direct-inward-dial" to both dial-peers 11 and 12.
This causes any incoming call to hang up straight away - I am assuming that the router is unable to route the call appropriately, and is hanging up immediately.
Not sure where to go from here, unfortunately... :o( Any thoughts?
I just noticed that your dialplan-pattern is wrong. You need to adjust your dialplan-pattern to what your DID range is. So for example if your DIDs are 212-555-8000 thru 8099 with 4 digit extensions, then your dialplan-pattern should be:
dialplan-pattern 1 2125558... extension-lenght 4
if it's 3 digit then:
dialplan-pattern 1 2125558... extension-lenght 3
HTH, please rate all posts!
Chris
381
