Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Problem with International Calls
I have a CM3.1(2c) with an H323 PSTN gateway (2610 router with
NM-HDV-E1 voice card). Everything works fine except with International calls. In some countries we can call just fine, but in some others we get a "disconnected" tone. I have done "debug isdn q931" on a failed called, and looks like that:
18:10:25: ISDN Se1/0:15: TX -> SETUP pd = 8 callref = 0x01CD
18:10:25: Bearer Capability i = 0x8090A3
18:10:25: Channel ID i = 0xA9839F
18:10:25: Display i = 'Pambos', 0x20, 'Charalambous'
18:10:25: Calling Party Number i = 0x00, 0x80, '551237', Plan:Unknown, T
ype:Unknown
18:10:25: Called Party Number i = 0x80, '009611396963', Plan:Unknown, Ty
pe:Unknown
18:10:25: ISDN Se1/0:15: RX <- SETUP_ACK pd = 8 callref = 0x81CD
18:10:31: ISDN Se1/0:15: RX <- DISCONNECT pd = 8 callref = 0x16AE
18:10:31: Cause i = 0x8090 - Normal call clearing
18:10:31: Progress Ind i = 0x8288 - In-band info or appropriate now avai
lable
18:10:31: ISDN Se1/0:15: TX -> RELEASE pd = 8 callref = 0x96AE
18:10:32: ISDN Se1/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x16AE
18:10:32: ISDN Se1/0:15: RX <- CALL_PROC pd = 8 callref = 0x81CD
18:10:35: ISDN Se1/0:15: TX -> DISCONNECT pd = 8 callref = 0x01CD
18:10:35: Cause i = 0x80E6 - Recovery on timer expiry
18:10:35: ISDN Se1/0:15: RX <- RELEASE pd = 8 callref = 0x81CD
18:10:35: ISDN Se1/0:15: TX -> RELEASE_COMP pd = 8 callref = 0x01CD
I get this "Recovery on timer expiry" and I don't know if its a problem on my side or the PSTN side. Also, before installing the H323 gateway, we had a DE-30+ PCI PRI selsius card, which worked great for so long with no problems.
Also, the IOS used is 12.2.7
Could anyone help please
Thank you very much
Re: Problem with International Calls
Hi, I had a simular problem.
Go to your serial interface 1/0:15, and set the following parameter;
isdn T310 60000
this should do the trick for your timeout problem.
success
Sascha
Silver
The international gateway is not sure if there are more digits to follow after the intial setup message, so it accepts the setup but waits an interdigit timeout period before attempting to send the call to the remote destination network. At the same time, the router waits the default T310 period of 10 seconds before it decides the call is not progressing and it clears the call with a 'recovery on timer expiry' clearing code.
What you need to do is to tell the international gateway the called number in the setup message has no more digits to follow - use the following D channel command:
interface serial 1/0:15
isdn sending-complete
This will set the sending complete field in the intial Q931 setup message so the PSTN gateway will accept the call and process it immediately.
Dear pambosch,
The switch is responding to the SETUP with a SETUP ACK, which suggests that for some reason it's expecting more digits from the GW, so it has entered an "overlap sending" state, where additional digits are now expected. No more digits come, so it clears the call. This suggests perhaps a dialing plan issue - be sure that the digits you are sending match what's expected by the switch, there may be digit deletion/insertion, etc required, or a change in provisioning of the ISDN line to fix this. Else it's possible the number is just being dialed incorrectly - presumably you've tried other international phone numbers. If the switch thought it could have routed the call on the initial digits sent, it would have attemped to do so, and not sent the SETUP ACK.
Bronze
I hope the following link can be usefull for your Problem.
http://www.cisco.com/warp/customer/788/AVVID/calls_to_mobile.html
Mehmet
ok guys,
my problem is solved now after increasing the T310 timer to 60000 msec.
Thank you all for the help.
180
