Problem with one way audio on 5300 gateways.
I can ping from site A(5300) to B(5300) and B to A but when a voice call is made site A hears it ringing and site B picks up and says hello and site A can hear that but when site A says hello site B does not hear that.
Anonymous
N/A
Re: Problem with one way audio on 5300 gateways.
1. Check if you have no ip routing in the router config. If
yes enable ip routing
2. check the codec negotiated by both side. Could be a codec miss- match in one direction.
3. turn on debug and see what address was sent int the h225 message
for rtp stream connection .
You have one way audio problem for which a few different causes can be found, below in the URL all possible causes are listed and the workaround is explained.
http://www.cisco.com/warp/customer/788/AVVID/fix_1way_voice.html
Check everything one by one. Let us know if you have further problems.
Hope this helps.
120
