Community Member
Problem with preferred codec and pre-ietf...
We have been seeing the pre-ietf codec showing up in our gateway's call history even though we have specified preference to not use it. The GW IOS version is 12.2(17a).
We have set the codec preference as follows:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
Anyone know why we are still seeing the pre-ietf codec in use? See call history entry below...
Thanks!
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
SessionProtocol=cisco
ProtocolCallId=
SessionTarget=ipv4:13.169.2.20
OnTimeRvPlayout=0
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=0 ms
LoWaterPlayoutDelay=0 ms
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CoderTypeRate=g729r8 pre-ietf
CodecBytes=0
AlertTimepoint=1065448373
CallerName=
CallerIDBlocked=False
OriginalCallingNumber=33188
OriginalCallingOctet=0x0
OriginalCalledNumber=35677
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x7F
TranslatedCallingNumber=33188
TranslatedCallingOctet=0x0
TranslatedCalledNumber=35677
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0xFF
GwReceivedCalledNumber=35677
GwReceivedCalledOctet3=0x80
GwOutpulsedCalledNumber=35677
GwOutpulsedCalledOctet3=0x80
GwReceivedCallingNumber=33188
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x81
GwOutpulsedCallingNumber=33188
GwOutpulsedCallingOctet3=0x0
GwOutpulsedCallingOctet3a=0x81
Username=Telephony call-legs: 2
SIP call-legs: 1
H323 call-legs: 1
MGCP call-legs: 0
Total call-legs: 4
Anonymous
N/A
Re: Problem with preferred codec and pre-ietf...
Silver
Hi Timothy,
There is a new bug opened for this issue, which is being reviewed internally by Cisco now. Here are the bug details.
CSCed37567 - show call history brief shows calls using g729r8 pre-ietf
"show call history voice brief" shows calls using g729r8 pre-ietf codec which is supposed to
be replaced by ietf g729r8 after IOS 12.0.5T. Customer is running 12.2.17a.
Customer has not enable pre-ietf on his dial-peers.
From call log:-
39CC : 613283898hs.124845 +-1 +33 pid:630 Answer 9720
dur 00:00:00 tx:0/0 rx:0/0 1 (unassigned number.)
IP 13.190.255.6:16936 rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-ietf
39D4 : 613285878hs.124848 +-1 +34 pid:630 Answer 9720
IP 13.190.255.6:18648 rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-ietf
This is also creating some confusion to customers.
Hope this helps!
Partha
151
