problem with reactive debug
Every time I start a reactive debugging session it times out and gives me an error:
RMI Error
Connection refused to host:[localhost:1099]; nested exception is: java.net.ConnectException: Connection refused
I have no firewalls running, and no other apps are using port 1099. I thought that the application editor opens port 1099 when it is started, but it isn't doing that. Any ideas?
1 ACCEPTED SOLUTION
Silver
Re: problem with reactive debug
This error implies that the RMI port that the Engine is listening on is different from what the Editor is referencing. The Engine Configuration page, by default references port 1099. Is this set to a different port? If so, go into the file:
C:\program files\wfavvid\wfengine.properties and change the RMI_PORT to match what is on the Engine Config Page. If not, change it back.
In addition to the above also check the following...
If you are using the CRA Editor remote from the server, check for the file c:\winnt\system32\ccn\ccndir.ini, make sure the LDAPURL is using ip
addresses to the LDAP source - ie, if DC Directory, the publisher/subscriber ip addresses.
Yogi
Check to make sure you are using the full workflow file name. (i.e. myscript.aef) Then make a call. If this still does not work, try running the workflow reactive debugger from the CRS server itself
Silver
Yogi
I believe that is the problem. I've got four installations of CRS, and that ccn file and registry settings make it difficult to work on things and test new features when I jump from client to client. It would be nice, for admin purposes, to have a profile utility that changes all those settings for you. Will anyone write one?
117
