Problem with same calls
I have install a voip solution and have a following problem:
Calls from mobilphone working fine
Debug:
Sep 4 20:12:52: ISDN Se1/0:15: RX <- SETUP pd = 8 callref = 0x5A00
Sep 4 20:12:52: Bearer Capability i = 0x8090A3
Sep 4 20:12:52: Channel ID i = 0xA18383
Sep 4 20:12:52: Calling Party Number i = 0x1183, '491705717992', Plan:ISDN, Type:International
Sep 4 20:12:52: Called Party Number i = 0xA1, '260766611', Plan:ISDN, Type:National
Sep 4 20:12:52: ISDN Se1/0:15: TX -> SETUP_ACK pd = 8 callref = 0xDA00
Sep 4 20:12:52: Channel ID i = 0xA98383
Sep 4 20:13:02: ISDN Se1/0:15: TX -> CALL_PROC pd = 8 callref = 0xDA00
Sep 4 20:13:02: ISDN Se1/0:15: TX -> ALERTING pd = 8 callref = 0xDA00
Sep 4 20:13:04: ISDN Se1/0:15: TX -> CONNECT pd = 8 callref = 0xDA00
Sep 4 20:13:04: ISDN Se1/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x5A00
Sep 4 20:13:04: ISDN Se1/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0x36, bchan 2, dsl 0
Sep 4 20:13:07: ISDN Se1/0:15: TX -> DISCONNECT pd = 8 callref = 0xDA00
Sep 4 20:13:07: Cause i = 0x8090 - Normal call clearing
Sep 4 20:13:07: ISDN Se1/0:15: RX <- RELEASE pd = 8 callref = 0x5A00
Sep 4 20:13:07: ISDN Se1/0:15: TX -> RELEASE_COMP pd = 8 callref = 0xDA00
call from the company outside to PSTN and back to the inside the company get a busy
Debug
Sep 4 20:13:51: ISDN Se1/0:15: TX -> SETUP pd = 8 callref = 0x0020
Sep 4 20:13:51: Sending Complete
Sep 4 20:13:51: Bearer Capability i = 0x8090A3
Sep 4 20:13:51: Channel ID i = 0xA98391
Sep 4 20:13:51: Calling Party Number i = 0x0081, '6602', Plan:Unknown, Type:Unknown
Sep 4 20:13:51: Called Party Number i = 0x80, '0260766611', Plan:Unknown, Type:Unknown
Sep 4 20:13:51: ISDN Se1/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x8020
Sep 4 20:13:51: Cause i = 0x82AC - Requested circuit/channel not available
Calls from USa to the inside the company in milan it doesn't worked
debug
Sep 4 20:15:32: ISDN Se1/0:15: RX <- SETUP pd = 8 callref = 0x6000
Sep 4 20:15:32: Bearer Capability i = 0x9090A3
Sep 4 20:15:32: Channel ID i = 0xA18387
Sep 4 20:15:32: Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Sep 4 20:15:32: Calling Party Number i = 0x00C3, Plan:Unknown, Type:Unknown
Sep 4 20:15:32: Called Party Number i = 0xA1, '260766611', Plan:ISDN, Type:National
Sep 4 20:15:32: Sending Complete
Sep 4 20:15:32: ISDN Se1/0:15: TX -> CALL_PROC pd = 8 callref = 0xE000
Sep 4 20:15:32: Channel ID i = 0xA98387
Sep 4 20:15:32: ISDN Se1/0:15: TX -> CONNECT pd = 8 callref = 0xE000
Sep 4 20:15:32: ISDN Se1/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x6000
Sep 4 20:15:32: ISDN Se1/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0x37, bchan 6, dsl 0
Sep 4 20:15:42: ISDN Se1/0:15: TX -> DISCONNECT pd = 8 callref = 0xE000
Sep 4 20:15:42: Cause i = 0x809C - Invalid number format (incomplete number)
Sep 4 20:15:42: Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Sep 4 20:15:42: Called Party Number i = 0xA1, '260766611', Plan:ISDN, Type:National
Sep 4 20:15:42: ISDN Se1/0:15: RX <- RELEASE pd = 8 callref = 0x6000
Sep 4 20:15:42: ISDN Se1/0:15: TX -> RELEASE_COMP pd = 8 callref = 0xE000
Sep 4 20:16:22: ISDN Se1/0:15: RX <- SETUP pd = 8 callref = 0x6200
Sep 4 20:16:22: Bearer Capability i = 0x9090A3
Sep 4 20:16:22: Channel ID i = 0xA1838B
Sep 4 20:16:22: Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Sep 4 20:16:22: Calling Party Number i = 0x00C3, Plan:Unknown, Type:Unknown
Sep 4 20:16:22: Called Party Number i = 0xA1, '260766611', Plan:ISDN, Type:National
Sep 4 20:16:22: Sending Complete
Sep 4 20:16:22: ISDN Se1/0:15: TX -> CALL_PROC pd = 8 callref = 0xE200
Sep 4 20:16:22: Channel ID i = 0xA9838B
Sep 4 20:16:22: ISDN Se1/0:15: TX -> CONNECT pd = 8 callref = 0xE200
Sep 4 20:16:22: ISDN Se1/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x6200
Sep 4 20:16:22: ISDN Se1/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0x38, bchan 10, dsl 0
Sep 4 20:16:32: ISDN Se1/0:15: TX -> DISCONNECT pd = 8 callref = 0xE200
Sep 4 20:16:32: Cause i = 0x809C - Invalid number format (incomplete number)
Sep 4 20:16:32: Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Sep 4 20:16:32: Called Party Number i = 0xA1, '260766611', Plan:ISDN, Type:National
Sep 4 20:16:32: ISDN Se1/0:15: RX <- RELEASE pd = 8 callref = 0x6200
Sep 4 20:16:32: ISDN Se1/0:15: TX -> RELEASE_COMP pd = 8 callref = 0xE200
Who has a tip for me to solve this problem.
Thanks and best regards,
Carsten
1 REPLY
Re: Problem with same calls
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
203
