Silver
problem with sip-ua
Hi folks,
I've a problem with a voip ISP that assigns a URINUM (the internal phone number) and uses an alphanumeric URI as username for authentication.
In my conf I've something like that:
dial-peer voice 50 pots
destination-pattern URINUM
port 1
sip-ua
authentication username URI password xxxxxxxx
calling-info pstn-to-sip from number set URINUM
The problem is: from debug ccsip I see that the sip-ua try to register with 'sip:URINUM@sip.ISP.dom' and not 'sip:URI@sip.ISP.dom' ... that's clear, normally all SIP registrations that I've already seen work in that way.
The result is: answer 'SIP/2.0 403 Forbidden'
Any advice will be appreciated
Andrea
Silver
Re: problem with sip-ua
Received: SIP/2.0 403 Forbidden means username and password configured was wrong
Silver
Correct. And thanks for your answer.
But normally we have username=URINUM (voip number).
In my case, username is alphanumeric, and not =URINUM.
"12345" is my number
"testuser" is my username
"testpass" my password
my conf is:
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
voice-port 1
cptone IT
timeouts interdigit 4
destination-pattern 12345
port 1
dial-peer voice 200 voip
description ISP-out
destination-pattern .T
session protocol sipv2
session target dns:sip..dom:5060
dtmf-relay rtp-nte
voice-class codec 1
no vad
sip-ua
authentication username "testuser" password "testpass"
calling-info pstn-to-sip from number set 12345
set pstn-cause 6 sip-status 503
set pstn-cause 18 sip-status 408
set pstn-cause 27 sip-status 502
set pstn-cause 31 sip-status 480
set pstn-cause 44 sip-status 503
set pstn-cause 58 sip-status 503
set pstn-cause 88 sip-status 503
set pstn-cause 95 sip-status 503
set pstn-cause 102 sip-status 504
set pstn-cause 111 sip-status 500
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry prack 9
retry rel1xx 10
retry subscribe 10
timers expires 60000
timers comet 100
timers notify 100
registrar dns:sip..dom:5060 expires 3600
sip-server dns:sip..dom:5060
this is my debug:
Sent:
REGISTER sip:sip..dom:5060 SIP/2.0
Via: SIP/2.0/UDP 88.149.168.xx:5060;branch=z9hG4bKAEF7C6
To: "12345" <12345>.dom>
Date: Fri, 07 Jul 2006 08:24:42 GMT
Call-ID: 7F4E3647-9CE11DB-8009D82E-9F09B043
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1152260682
CSeq: 2726 REGISTER
Contact: <>12345@88.149.168.xx:5060>
Expires: 3600
Content-Length: 0
Received:
To: "12345" <12345>.dom>;tag=as0832eec2
CSeq: 2726 REGISTER
User-Agent: www..dom
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY
Contact: <>12345@88.149.128.xx>
Content-Length: 0
DuffyGate#sh sip-ua reg stat
Line peer expires(sec) registered
12345 50 61 no
what could I do?
Andrea
Hi Andrea,
403 Forbidden indicates that the sip proxy response that the user (12345 in your case) does not exist in the your provider domain.
The SIP Proxy expect a testuser instead of 12345.
The sip proxy don't even try to authenticated you.
Once you send the correct user id, only then the sip proxy will challenge you with 401 unauthorized
Pls test following:-
1. Use a normal SIP client and try to register using testuser@yourprovidersip
This will verify that this username is existed.
2. Try to remove this line from your config, or any config that have 12345
What we need to verify is the the gw can register using testuser@yourprovidersip.
SS
Silver
hi ngss,
1- it works fine with X-lite sip client
2- it doesn't work, even if:
no calling-info pstn-to-sip from number set 12345
no dial-peer voice 50 pots
now the 'sh sip-ua reg stat' says:
DuffyGate#
and the debug says nothing.
with dial-peer voice 50 pots:
Jul 14 08:13:55.680: //-1/000000000000/SIP/Error/act_register_new_message: Message Code Class 4xx Method Code 100 not implemented for REGISTER
Andrea
Hi Andrea,
I see what is happening here.
If you try to register to a SIP Proxy, you must have the dial-peer ... pots command.
And it will take the your destination pattern as your sip id. that's why you see it try to register using 12345@...
Now try to use destination-pattern testuser in your pots dial-peer. It will then register with this id to register, and should authenticated ok.
If you need change the testuser to 12345. use traslate command.
SSng
Silver
DuffyGate(config-dial-peer)#destination-pattern testuser
Incorrect format for E.164 Number
regular expression must be of the form ^[][^0-9,A-F#*.?+%()-]*T?(\$)?$
what about that?
Andrea
Hi Andrea,
Use authentication command in the dial-peer pots.
It should work.
Something like this
dial-peer 10 ... pots
authentication username passwors xxxx
Pls give it a try.
Sorry not able to response ealier as I am too busy lately.
SS
Silver
No way :(
conf
description ISP-out
voice-class codec 1
session target dns:sip.ISP.dom:5060
dtmf-relay rtp-nte
no vad
destination-pattern
port 1
authentication username password
sip-ua
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry prack 9
retry rel1xx 10
retry subscribe 10
timers comet 100
timers notify 100
registrar dns:sip.ISP.dom:5060 expires 3600
sip-server dns:sip.ISP.dom:5060
Debug
Jul 26 09:03:06.599: //-1/000000000000/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Jul 26 09:03:06.599: //-1/000000000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x82633640 key=D3D7D407-1BBB11DB-8002D6F8-B82715AF
Jul 26 09:03:06.603: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone summertime to SIP default timezone = GMT
Jul 26 09:03:06.611: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.ISP.dom:5060 SIP/2.0
Via: SIP/2.0/UDP 88.149.166.xx:5060;branch=z9hG4bK22654
To: "" <>@sip.ISP.dom>
Date: Wed, 26 Jul 2006 09:03:06 GMT
Call-ID: D3D7D407-1BBB11DB-8002D6F8-B82715AF
Max-Forwards: 70
Timestamp: 1153904586
CSeq: 3 REGISTER
Contact: <>@88.149.166.xx:5060>
Expires: 3600
Content-Length: 0
Jul 26 09:03:06.655: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 88.149.128.xx:5060
Jul 26 09:03:06.683: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: "" <>@sip.ISP.dom>;tag=as758c1d36
CSeq: 3 REGISTER
User-Agent: www.ISP.dom
Contact: <>@88.149.128.xx>
Content-Length: 0
Jul 26 09:03:06.687: //-1/000000000000/SIP/Error/act_register_new_message: Message Code Class 4xx Method Code 100 not implemented for REGISTER
Jul 26 09:03:06.687: //-1/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
Jul 26 09:03:06.691: //-1/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x82633640 key=D3D7D407-1BBB11DB-8002D6F8-B82715AF
Jul 26 09:03:06.691: //-1/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Jul 26 09:03:06.695: //-1/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 82633640
Andrea
2428
