Problem with the sip alg function in ios
I have a problem to get the sip alg function to work correctly in our 7200 12.3(14)T4.
Our setup is as follows:
The sip server and the cisco_MGW are on the inside (private addresses).
The client is on the outside.
When the client send an INVITE to the outside interface, the alg change the destination address and forward it to the sip-server.
The problem is that when the sip server send 183 PROGRESS message, the alg doesn't change the private source ip address to a public source address.
The alg also miss to change the media part in the sdp body,but it change record-route parameter.
This is my configuration:
interface FastEthernet1/0
ip address x.x.x.x
no ip redirects
no ip unreachables
ip nat outside
ip virtual-reassembly
duplex full
interface FastEthernet4/0.10
encapsulation dot1Q 10
ip address 192.168.21.1 255.255.255.252
ip nat inside
no snmp trap link-status
no cdp enable
ip nat inside source static tcp 192.168.101.6 53 x.x.x.x 53
ip nat inside source static udp 192.168.101.6 53 x.x.x.x 53
ip nat inside source static tcp 192.168.101.6 5060 x.x.x.x 5060
ip nat inside source static udp 192.168.101.6 5060 x.x.x.x 5060
Could somebody tell me if I have missed anything.
Regards Niklas
Bronze
Re: Problem with the sip alg function in ios
Try disabling the following commands
1. fixup protocol h323 ras 1718-1719
2. fixup protocol sip 5060
3. fixup protocol sip udp 5060
4. fixup protocol skinny 2000
It was not possible to add this commands.
I use following IOS release:
12.3(14)T4
/Niklas
207
