Community Member
Problem with the softkey exit ?
I have a problem with the exit softkey.
I create some xml file as this :
<?xml version="1.0" encoding="iso-8859-1" ?>
<CiscoIPPhoneMenu>
<Title>Annuaire</Title>
<Prompt>Selectionner</Prompt>
<MenuItem>
<Name>Mon agence</Name>
<URL>http://myurl</URL>
</MenuItem>
<MenuItem>
<Name>Autre agence</Name>
<URL>http://myurl2</URL>
</MenuItem>
<SoftKeyItem>
<Name>Select.</Name>
<URL>SoftKey:Select</URL>
<Position>1</Position>
</SoftKeyItem>
<SoftKeyItem>
<Name>Quitter</Name>
<URL>SoftKey:Exit</URL>
<Position>3</Position>
</SoftKeyItem>
</CiscoIPPhoneMenu>
This file is generate by a php script.
I send this header :
header("Content-type:text/xml; charset:ISO-8859-1;");
header("Cache-Control: no-cache, must-revalidate");
$expire = date('D, d M Y H:i:s', time()-3600*24)." GMT";
header("Expires: ".$expire);
header("Connection: close");
The problem is this:
- i load the first page when i select the a service.
- from this page i go an other page, and other if i want
- if on a page i have the exit softkey, i can push it, but the action is not good.
When i push a button with a exit softkey, my phone make a "back" (the previous page).
So i can never realy exit my application.
I used an Cisco IP Phone 7940 series.
Can you help me please ?
thank
Aurelien
Re: Problem with the softkey exit ?
If you want to quit the application, use Key:Services instead.. that'll do the trick. If you search for SoftKey:Exit in this forum, you'll find that basically it's a magic button and does whatever it feels like. I've given up on trying to understand Exit and instead resort to SoftKey:Exit. Likewise, to get back a page, I use an url, and not Exit/Cancel.
Community Member
i'm a .net developer,but i think there are usefull for you~
"Response.Expires = -1;"
605
