problem with the voice volume between incoming and outgoing calls
Hi all.
I have a situation with volume calls.
1.- When the calls are originated in the PSTN to the IP Phones, the volume is ok in both sites.
2.- When the calls is originated in the IP Phones to the PSTN, the person in the PSTN listens very low.
I try to adjust the volume in the voice-port configuration, increasing the input and output db value, but not if I am doing it well or if I need adjust the configuration in other part.
The router 2801 have a CCME ver 4, this router is connected to PBX with a E1 and the PBX have the PSTN Digital trunks.
this is the voice router configuration:
voice-card 0
dsp services dspfarm
voice service voip
supplementary-service h450.12
controller E1 0/0/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-12 type e&m-immediate-start dtmf dnis
description to the PBX
voice-port 0/0/0:0
auto-cut-through
input gain 4
output attenuation 4
playout-delay nominal 200
playout-delay minimum low
bearer-cap Speech
1 REPLY
Bronze
Re: problem with the voice volume between incoming and outgoing
Try using a negative value in the output attenuation setting. My understanding is that negative values in the the output attenuation increases the volume out to the PSTN. Make small adjustments as you increase the chance for echo. Positive values decrease the volume.
Larry
114
