PROBLEM WITH UNITY 4.0.2 (LOTUS NOTES)
WHAT IS THE MEAN OF THIS ERROR ???
EVT_AVDOHMSG_MALINITFAILED
Source: CiscoUnity_Doh
Message: Doh logon failed due to messaging component initialization error: %1
Doh logon failed due to messaging component initialization error: Unspecified error
For more information, click: http://www.CiscoUnitySupport.com/find.php
Re: PROBLEM WITH UNITY 4.0.2 (LOTUS NOTES)
Was that the only error? I'd expect to see MALLN errors as well if the messaging component could not start.
If you just got this once, reboot, and it goes away, I would not worry about it. Probably a timing issue because the DOH came up before the MALLN was finished coming up. Same thing if the system worked fine despite this error.
If on the other hand you get this consistently and the system is unusable, open a case with Cisco TAC, because we're going to have to do some troubleshooting of your system.
We have at this time the following problem
When I leave a mesage the light indicator does not working (ON) and when I wan to check a message on the phone I digit the key messages ,digit my password an then the system said: " THE SYSTEM CANT NOT BE ACCESS AT THIS MOMENT
I NEED REPAIR THIS PROBLEM ,,,What is your recomendation????
126
