I have the following scenario:
ROUTER_B
2 FXO>ROUTER_A ------ F. R. CLOUD -----ROUTER_C<2 FXO ports
<p>
The WAN provider gives me 2 PVC's: ROUTER_B <-> ROUTER_A
and ROUTER_B<->ROUTER_C
So ROUTER_A is at two hops from ROUTER_C. <br>
Voice calls between A and C works fine as long as the data traffic
doesn't reach a certain level, in wich voice quality quickly degrades.<br>
Previously I've used RSVP to acomplish QoS but always the routers
where directly connected or at least in the same F.R. PVC, etc.
The same configuration here doesn't work.<br>
My doubt is: is possible for this to work at all? If so, wich QoS
method should I use?
Any sample configuration?
Thanks in advance for any hint or suggestion
