Problem with Web Interface in an IOS Telephony Service system
mcoulibaly
The web interface is work even if i make all configuration normal. Any help is wellcome !!!!
carenas123
Level 5
Level 5
Hope you have copied all the files required for Web access. What kind of issues, you are facing with this?
Some of the issues can be discovered using the "debug ip http transactions" and "debug ip http authentication" commands.
thusain
Level 4
Level 4
Please post your config so we can take a look. Andlo a little more detail as to what you mean that the web interface is not working, is it no coming up, no prompt for username and password, changes do not take affect?
