Problems displaying graphics on IP Phone
I am trying to send images to my IP Phone using the CiscoIPPhoneImage tag. I am running CM 3.33, so that bug that everyone is talking about is not a factor I assume. I have gotten the Push2Phone application to work, but no other graphics using a Push command will work. I have tried using both asp and xml files, but neither will show up on the phone. Most times, the phone will not even display it is doing anything. I cannot figure this out. I posted the script below. Any ideas? Thanks.
<%@ language=Javascript %>
Response.ContentType="text/xml";
Response.Write("<CiscoIPPhoneImage><Title>LM</Title><LocationX>-1</LocationX><LocationY>-1</LocationY><width>125</width><Height>23</Height><Depth>2</Depth><Data>Data here</Data>");
Response.write("<Prompt>This is cool</Prompt></CiscoIPPhoneImage>");
Update: I fixed the problem. I just renamed the CIP file to xml and the images display perfectly. Not sure why the other files weren't working, but now it does.
1 REPLY
Re: Problems displaying graphics on IP Phone
Yes, with this tag, you must send the CIP data in an xml document. I am glad that you have gotten this resolved. :)
137
