Problems Enabling RSVP
I am having problems enabling RSVP on a pair of 3640's connected via a hdlc ptp link.
Having entered the commands
Global - call rsvp-sync
Interface - bandwidth 32
Interface - ip rsvp bandwidth 24 24
Interface - fair-queue 64 16 1
Dial-peer - req-qos guaranteed-delay
Dial-peer - acc-qos guaranteed-delay
I just get engaged calls, the RSVP show commands do not show any reservations!
1 REPLY
Anonymous
N/A
Re: Problems Enabling RSVP
When ever you enable RSVP and req-qos, please make
sure that enough bandwidth is reserved for the voice call,
else call will be dropped.
You've reserved 24Kbps while g729 codec used 26bps for one
vocie call i.e over that the reservable bandwidth and
since req-QOS guaranteed-delay means:-
RSVP reserves bandwidth and guarantees a minimum bit rate and preferential
queuing if the bandwidth reserved is not exceeded i.e RSVP is attempted and if RSVP
fails, the call is released.
Try increasing the reserved bandwidht which in your caes would be more than 75% of 32kbps total interface bandwidth.
Solution increase interface bandwidht first and recalculate the 75% which should be far higher than 26Kbps at least for one voice call.
90
