09-24-2003 11:06 PM - last edited on 03-25-2019 06:39 PM by ciscomoderator
I have installed a Cisco Call Manager 3.3.2 (as a publisher) on a MCS7835-1266.
The Installation was completed the CCM-Services and the W2K and CCM-Servicability don´t start. Database layer monitor hung on starting.
I couln´t start the services manually.
After upgrading to CCM 3.3.sr1 (installing all winos- /ccm- updates and patches it works.
Now I want to install a Cisco Call Manager 3.3.2 as a subscriber on a MCS7835-2400.
The winos installation seams to be successful. The CCM installation ends with an error and the rollback of the installation starts.
Someone tolds me, that the installation is not successful, because the version of the publishers DC-directory is not correct.
The current version is 3.3.3.14 .
Can anyone help me to solve this Problem?
09-25-2003 02:48 AM
You are running into thsi issue:
CSCec00220 - Install of new Subscriber with 3.3(2) CDs into 3.3(3) cluster fails
Install of NEW Subscriber server with version 3.3(2) CD's into a
version 3.3(3) CallManager cluster fails.
In the past, with previous versions of CallManager as far back as
3.0, a customer could always install a new Subscriber using an
earlier version of CD's and then upgrade that subscriber to the
version currently installed on the Publisher.
This does not work with with an existing 3.3(3) cluster when
attempting to initially install a new subscriber using 3.3(2) CD's.
They should obtain 3.3(3) CD's in order for the installation to be
successful due to DC Directory checking the version installed on the
Publisher.
The issue can be identified with IntegratedSetup.trc showing:
Read remote registry to get IntegratedInstall version on Publisher
Publisher's IntegratedInstall version:"3.3.3.14"
Subscriber's install version is diffeent from Publisher's.
Install is aborted/cancelled...
At the time of this bug being raised 3.3(3) CD's have not yet FCS'ed
Work-around (will get you past this point but cause other issues):
Change the value of "IntegratedInstallVersion" on Publisher registry
"HKEY_LOCAL_MACHINE\Cisco Systems, Inc.\Directory Configuration" to
"3.3.2.10". Please note down the existing value before changing it to
3.3.2.10.
This will enable CallManager 3.3(2) to be installed on Subscriber as
far as directory install is concerned.
Now, once Subscriber install is complete, reset the
"IntegratedInstallVersion" on Publisher to original value and upgrade
the Subscriber to 3.3(3).
Resolution:
Get 3.3(3) install CD's
