Problems which dial-peer to call manager cluster
now i´ve a problems on the gateway.
on the gateway have two dial-peer to publisher and subscriber. but when the call incoming from the pstn route to the publisher the call is no complete, i listen message from the call manager "the user can not take the call at this time", if the incoming call route to the subscriber, the call is answered by final user.
actually all phone registred on the subscriber.
dial-peer voice 13421 voip
description To Send directo "7877613717" Los Paseos 021 Primary
preference 1
max-conn 10
destination-pattern 3421
session target ipv4:112.1.120.231
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
dial-peer voice 23421 voip
description To Send directo "7877613717" Los Paseos 021 backup
preference 2
max-conn 3
session target ipv4:112.1.120.232
voice-class codec 1
voice-class h323 1
i´ve realice a test and activate debug ccnapi inout.
first test "dial-peer voice 23421 voip" SHUT DOWN "the incoming call is answere by de publisher and listen message ...the user can not take the call at this time
voip ccapi inout debugging is on
BBVA-CVG0095#
BBVA-CVG0095#
BBVA-CVG0095#
BBVA-CVG0095#ter
BBVA-CVG0095#terminal mo
BBVA-CVG0095#terminal mon
BBVA-CVG0095#terminal monitor
BBVA-CVG0095#
Nov 21 2011 19:55:44.373 GMT: //-1/28F0F1598007/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=7877923524
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=7877613717
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Nov 21 2011 19:55:44.373 GMT: //-1/28F0F1598007/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x312F97E8, Call Info(
   Calling Number=7877923524,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=7877613717(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=77771, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Nov 21 2011 19:55:44.373 GMT: //-1/28F0F1598007/CCAPI/ccCheckClipClir:
   In: Calling Number=7877923524(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=7877923524(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Nov 21 2011 19:55:44.373 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 21 2011 19:55:44.373 GMT: :cc_get_feature_vsa malloc success
Nov 21 2011 19:55:44.373 GMT:  cc_get_feature_vsa count is 1
Nov 21 2011 19:55:44.373 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:726518920,feature_id:10
Nov 21 2011 19:55:44.373 GMT: //10/28F0F1598007/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7877923524(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=7877613717(TON=Unknown, NPI=Unknown))
Nov 21 2011 19:55:44.373 GMT: //10/28F0F1598007/CCAPI/cc_process_call_setup_ind:
   Event=0x3121D110
Nov 21 2011 19:55:44.373 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7877613717
Nov 21 2011 19:55:44.373 GMT: //10/28F0F1598007/CCAPI/ccCallSetContext:
   Context=0x2B4E87F8
   >>>>CCAPI handed cid 10 with tag 77771 to app "_ManagedAppProcess_Default"
Nov 21 2011 19:55:44.377 GMT: //10/28F0F1598007/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Nov 21 2011 19:55:44.377 GMT: //10/28F0F1598007/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=13421, Params=0x2B4E9B50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Nov 21 2011 19:55:44.377 GMT: //10/28F0F1598007/CCAPI/ccCheckClipClir:
   Destination Pattern=3421, Called Number=3421, Digit Strip=FALSE
   Called Number=3421(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=28F0F159-13D3-11E1-8007-D0D0FDD46BD0, Outgoing Dial-peer=13421
Nov 21 2011 19:55:44.377 GMT: //10/28F0F1598007/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=3421
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 21 2011 19:55:44.377 GMT: //10/28F0F1598007/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x30BE1D80, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=7877923524,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=3421(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=13421, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Nov 21 2011 19:55:44.377 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 21 2011 19:55:44.377 GMT: :cc_get_feature_vsa malloc success
Nov 21 2011 19:55:44.377 GMT:  cc_get_feature_vsa count is 2
Nov 21 2011 19:55:44.377 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:726518696,feature_id:11
Nov 21 2011 19:55:44.377 GMT: //11/28F0F1598007/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Nov 21 2011 19:55:44.377 GMT: //11/28F0F1598007/CCAPI/ccCallSetContext:
   Context=0x2B4E9B00
Nov 21 2011 19:55:44.377 GMT: //10/28F0F1598007/CCAPI/ccSaveDialpeerTag:
Nov 21 2011 19:55:44.385 GMT: //11/28F0F1598007/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x30BE1D80, Call Id=11
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Nov 21 2011 19:55:44.385 GMT: //10/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Nov 21 2011 19:55:44.385 GMT: //11/28F0F1598007/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=11
Nov 21 2011 19:55:44.385 GMT: //11/28F0F1598007/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Nov 21 2011 19:55:44.385 GMT: //11/28F0F1598007/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Nov 21 2011 19:55:44.385 GMT: //11/28F0F1598007/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30BE1D80, Tag=0x0, Call Id=11,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Nov 21 2011 19:55:44.385 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 21 2011 19:55:44.385 GMT: :cc_free_feature_vsa freeing 2B4DCBA0
Nov 21 2011 19:55:44.385 GMT:  vsacount in free is 1
Nov 21 2011 19:55:44.389 GMT: //10/28F0F1598007/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Nov 21 2011 19:55:44.389 GMT: //10/28F0F1598007/CCAPI/cc_api_get_transfer_info:
Nov 21 2011 19:55:44.457 GMT: //10/28F0F1598007/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x312F97E8, Tag=0x0, Call Id=10,
Nov 21 2011 19:55:44.457 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 21 2011 19:55:44.457 GMT: :cc_free_feature_vsa freeing 2B4DCC80
Nov 21 2011 19:55:44.457 GMT:  vsacount in free is 0
Second test "dial-peer voice 23421 voip" is UP "the incoming call is answer by the final user ...the call is completed.
Nov 21 2011 19:59:03.823 GMT: //-1/9FD29B858008/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=7872730876
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=7877613717
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 21 2011 19:59:03.823 GMT: //-1/9FD29B858008/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3123D918, Call Info(
   Calling Number=7872730876,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Nov 21 2011 19:59:03.823 GMT: //-1/9FD29B858008/CCAPI/ccCheckClipClir:
   In: Calling Number=7872730876(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=7872730876(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Nov 21 2011 19:59:03.823 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 21 2011 19:59:03.823 GMT: :cc_get_feature_vsa malloc success
Nov 21 2011 19:59:03.823 GMT:  cc_get_feature_vsa count is 1
Nov 21 2011 19:59:03.823 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:726482656,feature_id:12
Nov 21 2011 19:59:03.823 GMT: //12/9FD29B858008/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7872730876(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Nov 21 2011 19:59:03.823 GMT: //12/9FD29B858008/CCAPI/cc_process_call_setup_ind:
   Event=0x3121D110
Nov 21 2011 19:59:03.823 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Nov 21 2011 19:59:03.827 GMT: //12/9FD29B858008/CCAPI/ccCallSetContext:
   Context=0x2B4EAE08
Nov 21 2011 19:59:03.827 GMT: //12/9FD29B858008/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 12 with tag 77771 to app "_ManagedAppProcess_Default"
Nov 21 2011 19:59:03.827 GMT: //12/9FD29B858008/CCAPI/ccCallProceeding:
Nov 21 2011 19:59:03.827 GMT: //12/9FD29B858008/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=13421, Params=0x2B4EC160, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Nov 21 2011 19:59:03.827 GMT: //12/9FD29B858008/CCAPI/ccCheckClipClir:
   Guid=9FD29B85-13D3-11E1-8008-D0D0FDD46BD0, Outgoing Dial-peer=13421
Nov 21 2011 19:59:03.827 GMT: //12/9FD29B858008/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=3421
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 21 2011 19:59:03.827 GMT: //12/9FD29B858008/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=7872730876,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Nov 21 2011 19:59:03.827 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 21 2011 19:59:03.827 GMT: :cc_get_feature_vsa malloc success
Nov 21 2011 19:59:03.827 GMT:  cc_get_feature_vsa count is 2
Nov 21 2011 19:59:03.827 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:726482432,feature_id:13
Nov 21 2011 19:59:03.827 GMT: //13/9FD29B858008/CCAPI/ccIFCallSetupRequestPrivate:
Nov 21 2011 19:59:03.827 GMT: //13/9FD29B858008/CCAPI/ccCallSetContext:
   Context=0x2B4EC110
Nov 21 2011 19:59:03.827 GMT: //12/9FD29B858008/CCAPI/ccSaveDialpeerTag:
Nov 21 2011 19:59:03.835 GMT: //13/9FD29B858008/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x30BE1D80, Call Id=13
Nov 21 2011 19:59:03.835 GMT: //12/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Nov 21 2011 19:59:03.835 GMT: //13/9FD29B858008/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=13
Nov 21 2011 19:59:03.835 GMT: //13/9FD29B858008/CCAPI/ccCallDisconnect:
Nov 21 2011 19:59:03.839 GMT: //13/9FD29B858008/CCAPI/ccCallDisconnect:
Nov 21 2011 19:59:03.839 GMT: //13/9FD29B858008/CCAPI/cc_api_get_transfer_info:
Nov 21 2011 19:59:03.839 GMT: //13/9FD29B858008/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30BE1D80, Tag=0x0, Call Id=13,
Nov 21 2011 19:59:03.839 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 21 2011 19:59:03.839 GMT: :cc_free_feature_vsa freeing 2B4D3DF8
Nov 21 2011 19:59:03.839 GMT:  vsacount in free is 1
Nov 21 2011 19:59:03.839 GMT: //12/9FD29B858008/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=23421, Params=0x2B4ED468, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Nov 21 2011 19:59:03.839 GMT: //12/9FD29B858008/CCAPI/ccCheckClipClir:
   Guid=9FD29B85-13D3-11E1-8008-D0D0FDD46BD0, Outgoing Dial-peer=23421
Nov 21 2011 19:59:03.839 GMT: //12/9FD29B858008/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=3421
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 21 2011 19:59:03.839 GMT: //12/9FD29B858008/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=23421, Call Count On=FALSE,
Nov 21 2011 19:59:03.839 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 21 2011 19:59:03.839 GMT: :cc_get_feature_vsa malloc success
Nov 21 2011 19:59:03.839 GMT:  cc_get_feature_vsa count is 2
Nov 21 2011 19:59:03.839 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:726482432,feature_id:14
Nov 21 2011 19:59:03.839 GMT: //14/9FD29B858008/CCAPI/ccIFCallSetupRequestPrivate:
Nov 21 2011 19:59:03.839 GMT: //14/9FD29B858008/CCAPI/ccCallSetContext:
   Context=0x2B4ED418
Nov 21 2011 19:59:03.839 GMT: //12/9FD29B858008/CCAPI/ccSaveDialpeerTag:
Nov 21 2011 19:59:05.847 GMT: //14/9FD29B858008/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Nov 21 2011 19:59:05.847 GMT: //14/9FD29B858008/CCAPI/cc_api_call_proceeding:
   Interface=0x30BE1D80, Progress Indication=NULL(0)
Nov 21 2011 19:59:05.863 GMT: //14/9FD29B858008/CCAPI/cc_api_set_called_ccm_detected:
Nov 21 2011 19:59:05.863 GMT: //14/9FD29B858008/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
Nov 21 2011 19:59:05.863 GMT: //14/9FD29B858008/CCAPI/cc_api_call_alert:
   Interface=0x30BE1D80, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Nov 21 2011 19:59:05.863 GMT: //12/9FD29B858008/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Nov 21 2011 19:59:06.043 GMT: //14/9FD29B858008/CCAPI/cc_api_set_called_ccm_detected:
Nov 21 2011 19:59:06.043 GMT: //14/9FD29B858008/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x30BE1D80, Call Id=14
Nov 21 2011 19:59:06.043 GMT: //14/9FD29B858008/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Nov 21 2011 19:59:06.043 GMT: //14/9FD29B858008/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
Nov 21 2011 19:59:06.043 GMT: //12/9FD29B858008/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=12
Nov 21 2011 19:59:24.643 GMT: //12/9FD29B858008/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x3123D918, Call Id=12
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Nov 21 2011 19:59:24.643 GMT: //12/9FD29B858008/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=12
Nov 21 2011 19:59:24.643 GMT: //14/9FD29B858008/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Nov 21 2011 19:59:24.643 GMT: //14/9FD29B858008/CCAPI/cc_api_get_transfer_info:
Nov 21 2011 19:59:24.643 GMT: //12/9FD29B858008/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Nov 21 2011 19:59:24.643 GMT: //12/9FD29B858008/CCAPI/cc_api_get_transfer_info:
Nov 21 2011 19:59:24.647 GMT: //14/9FD29B858008/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30BE1D80, Tag=0x0, Call Id=14,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Nov 21 2011 19:59:24.647 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 21 2011 19:59:24.647 GMT: :cc_free_feature_vsa freeing 2B4D3DF8
Nov 21 2011 19:59:24.647 GMT:  vsacount in free is 1
Nov 21 2011 19:59:24.675 GMT: //12/9FD29B858008/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3123D918, Tag=0x0, Call Id=12,
Nov 21 2011 19:59:24.675 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 21 2011 19:59:24.675 GMT: :cc_free_feature_vsa freeing 2B4D3ED8
Nov 21 2011 19:59:24.675 GMT:  vsacount in free is 0
thanks in advance
JCA
Hi Friend,
Please find the disconnect cause code = 1 meaning.
Unallocated (unassigned) number.
This number is not in the routing table or it has no path across the ISDN cloud (network).
  1. Check routing table to see it the number is available.
  2. Check to make sure the correct digits were dialed and it is a valid number.
Please check the call manager services has been enabled in publisher
That reason code can mean a number of things
a) no IP connectivity or wrong ip routing
b) wrong inbound CSS
c) no H323 daemon running
d) the number does not exist on CUCM
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Jaime,
Thank You so much. You helped me realise that the problem was under b) wrong inbound CSS in my case.
Tiberie
8409
