Problems with 3600 and E+M cards.
I'm trying to set up some E+M trunks for the first time. I don't seem to be getting the dialled digits at the far end when I use the debug vpm signal command. I see them leaving the local end. We have a 2651 router at the distant end. Does anyone know any good URL's for setting these up ?
Phil.
1 REPLY
Re: Problems with 3600 and E+M cards.
For E&M wiring and configuration, the URLs below should be able to help:
http://www.cisco.com/warp/public/788/signalling/e_m_overview.html
http://www.cisco.com/warp/public/788/signalling/analog_em_ts.html
http://www.cisco.com/warp/public/788/signalling/21.html
1. Make sure wiring and pinouts are correct on both sides.
2. Make sure if you have winkstart, to RECEIVE wink after you send SEIZURE before digits are pulsed out. And vice versa if you are the transmitting side.
3. Make sure to run debugs with msec timestamps. This way you can count all the msec for timeout, etc.
Hope this helps.
137
