Community Member
Problems with DSP Gateway mgcp 2811
I've got a Callmanager 4.1(3), gateway with a ISDN Primary E1 and DSP PVDM2. But I don't archive enable the dsp's. I can make external call but I heard nothing. I don?t know where is the problem.
Here is the configuration:
MADRID_CC#sh run
Building configuration...
Current configuration : 2931 bytes
version 12.4
hostname MADRID_CC
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
resource policy
network-clock-participate wic 0
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.2.1 10.0.2.9
ip dhcp pool VOICE
network 10.0.2.0 255.255.255.0
option 150 ip 10.0.1.2
default-router 10.0.2.1
dns-server 10.0.1.2
ip host CALLMANAGER 10.0.1.2
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
controller E1 0/0/0
clock source internal
pri-group timeslots 1-31 service mgcp
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.113.34 255.255.255.224
no snmp trap link-status
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.0.2.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.113.33
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
cptone ES
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.0.1.2
ccm-manager config
mgcp
mgcp call-agent CALLMANAGER 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local FastEthernet0/0.2
sccp ccm 10.0.1.2 identifier 1 version 4.1
sccp ip precedence 3
sccp
sccp ccm group 988
associate ccm 1 priority 1
associate profile 1 register 172.16.113.34
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
maximum sessions 18
associate application SCCP
shutdown
call-manager-fallback
max-conferences 8 gain -6
limit-dn 7940 4
ip source-address 10.0.2.1 port 2002 strict-match
max-ephones 24
max-dn 15 dual-line preference 1
line con 0
line aux 0
line vty 0 4
scheduler allocate 20000 1000
end
MADRID_CC#
Thanks for your help.
See you.
Re: Problems with DSP Gateway mgcp 2811
Juan,
DSPs don't need to be enabled for voice calls. The router will try to use the available DSPs. To see if you are running out of DSPs then take a look at the router log buffer or syslog. You also have 18 transcoding sessions configured which equals 36 dsp channels on your router with a PVDM2 configuration. How many DSPs do you have in your router? You can determine this from a sh inventory or sh voice dsp detailed.
Please rate any helpful posts
Fred
Community Member
MADRID_CC#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811 , VID: V01 , SN: FCZ0949723J
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-1MFT-T1/E1 - 1
-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1 , VID: V01 , SN: FOC0947377Q
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: NA , SN: FOC10040Q6G
MADRID_CC#
MADRID_CC#sh voice dsp detailed
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
edsp 001 01 g729r8 p 0.1 IDLE 50/0/1.1
edsp 002 02 g729r8 p 0.1 IDLE 50/0/1.2
edsp 003 01 g729r8 p 0.1 IDLE 50/0/2.1
edsp 004 02 g729r8 p 0.1 IDLE 50/0/2.2
edsp 005 01 g729r8 p 0.1 IDLE 50/0/3.1
edsp 006 02 g729r8 p 0.1 IDLE 50/0/3.2
edsp 007 01 g729r8 p 0.1 IDLE 50/0/4.1
edsp 008 02 g729r8 p 0.1 IDLE 50/0/4.2
edsp 009 01 g729r8 p 0.1 IDLE 50/0/5.1
edsp 010 02 g729r8 p 0.1 IDLE 50/0/5.2
edsp 011 01 g729r8 p 0.1 IDLE 50/0/6.1
edsp 012 02 g729r8 p 0.1 IDLE 50/0/6.2
edsp 013 01 g729r8 p 0.1 IDLE 50/0/7.1
edsp 014 02 g729r8 p 0.1 IDLE 50/0/7.2
edsp 015 01 g729r8 p 0.1 IDLE 50/0/8.1
edsp 016 02 g729r8 p 0.1 IDLE 50/0/8.2
edsp 017 01 g729r8 p 0.1 IDLE 50/0/9.1
edsp 018 02 g729r8 p 0.1 IDLE 50/0/9.2
edsp 019 01 g729r8 p 0.1 IDLE 50/0/10.1
edsp 020 02 g729r8 p 0.1 IDLE 50/0/10.2
edsp 021 01 g729r8 p 0.1 IDLE 50/0/11.1
edsp 022 02 g729r8 p 0.1 IDLE 50/0/11.2
edsp 023 01 g729r8 p 0.1 IDLE 50/0/12.1
edsp 024 02 g729r8 p 0.1 IDLE 50/0/12.2
edsp 025 01 g729r8 p 0.1 IDLE 50/0/13.1
edsp 026 02 g729r8 p 0.1 IDLE 50/0/13.2
edsp 027 01 g729r8 p 0.1 IDLE 50/0/14.1
edsp 028 02 g729r8 p 0.1 IDLE 50/0/14.2
edsp 029 01 g729r8 p 0.1 IDLE 50/0/15.1
edsp 030 02 g729r8 p 0.1 IDLE 50/0/15.2
Firstly I tried with this configuration but It don't work:
-voice-card 0
dspfarm
Juan
Community Member
Try this command:
voice-port 0/0/0:15
compand-type a-law
this is needed to use the european ISDN coded.
Let me know
Community Member
Now I can detect some strange things.
With three phones (A, B, C)
I make a call from A to B. I can heard nothing.
I hold on the call (A-->B) and make a new call with the second line from A to C.
A-->B on hold
A-->C running
I can heard nothing between A and C but I can heard to A from B and B from A while the is on hold.
I hold on the call between A and C.
A-->B on hold
A-->C on hold
From B I can heard music on hold.
The dsp are actived.
----------------------------FLEX VOICE CARD 0 ------------------------------
*DSP VOICE CHANNELS*
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 g711ulaw 6.3.2 busy idle 0 0 0/0/0:15 31 0 1681/1772
C5510 001 02 g711ulaw 6.3.2 busy idle 0 0 0/0/0:15 30 0 444/488
C5510 001 03 None 6.3.2 idle idle 0 0 0 0/0
C5510 001 04 None 6.3.2 idle idle 0 0 0 0/0
C5510 001 05 None 6.3.2 idle idle 0 0 0 0/0
C5510 001 06 None 6.3.2 idle idle 0 0 0 0/0
C5510 001 07 None 6.3.2 idle idle 0 0 0 0/0
Gold
Juan,
Check with the provider if the E1 is using CRC4 or not. Check this parameter in the MGCP cpnfiguration in CallManager too.
Why are you using the 'clock source internal' command? I have several configurations and I don?t use that command.
Hope this helps,
Juan Luis
Community Member
Hi Juan Luis,
I have tried CRC4 and NO-CRC4 with 'clock source internal' and 'clock source external'. It run the same way.
A-->B on hold
A-->C running
A-->B on hold
A-->C on hold
Gold
Juan,
Sometimes, I had problems with the way that CallManager got the channels. Try to change, in the CallManager gateway configuration page, the parameter 'Channel Selection Order' to check if this could be the problem.
Juan Luis
Community Member
That was the problem.
Thanks a lot for your help.
Nice to met you.
Bye.
Gold
Please, don?t forget to rate the posts.
Juan Luis
313
