Problems with ISDN calls
Some calls from VoIP network to the PSTN fail. I use CISCO2620 with BRI ports. The calls which fail seems to be segmented. Debug isdn q.931&q.921 shows Cause i = 0x80D1 - Invalid call reference value
What does it mean? Where should I look to solve the problem ?
1 REPLY
Anonymous
N/A
Re: Problems with ISDN calls
You need to look at the q931 call setup,
to see what the call reference and options
are that are being complained about. So
the info before the cause code is generated
is important.
111
