Problems with ISDN QSIG on 1751
I'm connecting one 1751 on Siemens PBX through ISDN BRI QSIG port.
The IOS is 12.2(4)YH and the problem is that the router are trying to establish a conversation in channel 0 instead 1 or 2. Then the PBX refuse the incoming call.
Is there any way to configure the router to not use the channel 0 to establish a call?
Here goes the debug q.931
1w0d: ISDN BR1/0 Q931: TX -> SETUP pd = 8 callref = 0x00CB
Bearer Capability i = 0x9090A3
Standard = CCITT
Transer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98380
Exclusive, Channel 0 <-------------- {Here happens the problem}
Calling Party Number i = 0x0183, '0713'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0717'
Sending Complete
1w0d: ISDN BR1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80CB
Cause i = 0x85E418 - Invalid information element contents
1w0d: ISDN BR1/1 Q931: RX <- DISCONNECT pd = 8 callref = 0x0001
Cause i = 0x8090 - Normal call clearing
1w0d: ISDN BR1/1 Q931: TX -> RELEASE pd = 8 callref = 0x8001
Re: Problems with ISDN QSIG on 1751
Is there a specific reason that YH code is being used?
Try loading 12.2(11) and see if it works.
a 'debug isdn q931' will show the q931 messages where this is exchanged.
Because is the only version that support a NT/TE ISDN interface with QSIG signaling.
Refer to page: http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122relnt/1700/rn1700yh.htm#xtocid9
Is there any new IOS version?
272
