02-04-2004 12:14 PM - edited 03-13-2019 03:41 AM
Hi Community,
I´m having the following problem.
I´ve configured MGCP between Gateway and Callmanger.
Everything seems to work fine except one thing.
When I press the redial button or when I´m doing a call-setup with a CTI-Application then the call-setup fails.
In the callmanager-trace I can see the destination-number as one block and that no potential match exists.
When I´m setting up the call by typing the digits on the phone I can see in the trace the digits arriving one by one and the I´m having a match of the destination pattern.
I´m quite sure that there is only one thing I forgot to configure, but what is it?
My route-pattern is "0."
Thanks in advance for your any hint.
02-05-2004 12:30 AM
I guess your Route Pattern points to a RouteList. So you just have to set the service parameter 'Enable Overlap On RouteList' to TRUE. It should work.
jp
02-16-2004 03:35 AM
That´s it.
Thanks a lot !!
