problems with Off ramp faxing
Just trying to get this to work for my smaller sites.
On ramp faxing is ok, but get protocol error (111) returned from my router when trying to do an off ramp fax.
tried the manual approach telneting to the gateway on port 25
see below for input
Trying devrtr01.simplot.com.au (172.17.140.1, 25)... Open
220 DEVRTR01.simplot.com.au Cisco NetWorks ESMTP server
ehlo
250-DEVRTR01.simplot.com.au, hello <empty HELO/EHLO> [172.16.5.251] (really )
250-ENHANCEDSTATUSCODES
250-8BITMIME
250-PIPELINING
250-HELP
250-DSN
250 XACCOUNTING
mail from:richard.bradfield@simplot.com.au
250 2.5.0 Sender <richard.bradfield@simplot.com.au> ok
rcpt to:fax=095884451@DEVRTR01.simplot.com.au
250 2.1.5 Recipient <fax=095884451@DEVRTR01.simplot.com.au> ok, maps to `0958844
51' (cp=yes)
data
354 Enter mail, end with a single "."
this is a test this is a test
this is a test
554 5.3.0 An unknown error occurred
500 5.5.2 Unknown command ""
quit
221 2.3.0 Goodbye from DEVRTR01.simplot.com.au; closing connection
according to the document i have when you have entered the "." should get a message
like "message delivered to remote fax machine"
but just get
if I do a debug mmoip send fax 095884451
says its ok.
I am running this on a 3845 Router running
c3845-spservicesk9-mz.124-15.T8.bin
relevent config attached
note this is running standard H323 PSTN gateway without a problem.
209
